Question about Craftsman Measuring Tools & Sensors
Craftsman 5.5 amp Scrolling Sabre Saw Blade won't lock in place
I have a new Craftsman 5.5 amp Scrolling Sabre Saw with LaserTrac® & Worklight Model#17256.. I cannot get any blade to lock into the quick change lock. The blade will not go past the T to lock into place. I have tried in every setting with multiple blades.
riverotter
  • 58 Answers
SOURCE: changing the saw blade on a Ryobi Mitre saw
Usually there is a piece of metal around the motor you use to lock the motor by pushing it in then you can use a wrench to loosen the bolt holding the blade on. make sure you put the new blade in the same way the old one is.
Posted on Jan 22, 2009
  • 10865 Answers
SOURCE: loose replacement blade
First of all unplug the miter saw and then remove the blade. Now examine the saw to check the direction of rotation. Be sure you are putting the blade on so that the rotation arrow on the blade is pointing in the same direction as the rotation of the tool. Now reassemble. Be sure to use some muscle to put the blade on fairly tight. Now when you use the miter saw let the blade do the cutting, do not overwork the tool by trying to cut too fast. good luck.
Posted on Jan 25, 2009
  • 653 Answers
SOURCE: bought model 3400 skil table saw. have no manual.
Crank the blade up to its highest level using the knob on the side, then on the front of the saw loosen the lever and tilt the blade to whatever angle you want, using the gauge on the front as your guide. You can always go online to the Skil website and download a manual, or contact them about sending you one.
Posted on Feb 26, 2009
SOURCE: Solution for "changing blades on a milwaukee miter saw
Have you removed the old blade yet?
The blade lock my be broken off -- it should be a button on top of the motor.
This saw has left hand threads -- turn clockwise to loosen the bolt/nut.
If you can't find the blade lock, lower the saw onto a piece of wood llike a 2x4 to keep the blade from turning.
Posted on May 02, 2009
Editor925
  • 285 Answers
SOURCE: How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
Posted on May 29, 2009
Where is the blade lock for CRAFTSMAN 315.10951
quite possibly there is none . most people use a block of wood held against the blade.
Aug 16, 2014 | Sears Craftsman 7-1/4 in. Circular Saw...
I bent the depth of cut scale on a Craftsman 7-1/4 in. Circular Saw. How to true it so I can again set correct depths?
With the saw unplugged, lay it upside down on a bench or table. Put a small scrap of 2x4 against the blade and adjust until the depth of the blade matches the thickness of the 2x4. Lock it in place, Then bend or adjust the depth scale so that it reads 1-1/2 inches. Good luck.
Dec 10, 2012 | Sears Craftsman 7-1/4 in. Circular Saw...
Sabre saw- craftsman - 17256 - change blades
This saw uses a tool-free blade change. 1. Unplug the jigsaw 2. Place your finger on the lower edge of the see through blade guard, and pull it forward until it locks up in place 3. Lift the tool-free blade change holder (bright yellow piece above the blade), and insert the blade into the slot of the tool-free blade change holder. 4. Release the tool-free blade change holder to lock the blade in place. 5. Pull down on the blade to verify that the blade is securely locked in place. The teeth of the blade should be pointing forward and down. 5. Put the blade guard back down.
You can use with both 'T' & 'U' shanked blades.
Feel free to ask me any other questions about this saw.
Jan 06, 2011 | Craftsman Evolv 45 amp Jig Saw 17434
How do I change the saw blade on my 2 hp 7 1/4 saw?
If the saw doesn't have a locking mechanism for changing the blade then you will have to jam a piece of wood in the teeth of the blade so that it cannot turn. Remember safety first. Ensure the saw is unplugged and wear leather gloves when changing the blade. Use a socket or wrench to loosen the nut that holds the blade on and remove the blade. Use the reverse procedure to tighten the blade.
Oct 02, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Us to cut off a 1"steel pipe
Only if you use and metal cut off blade and an insert to make it fit the shaft.
Jun 23, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Can't tighten the blade- it spins
Use a round shaft screwdriver place between the blade teeth to prevent it from turning.
Mar 04, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
My blade broke off in the lock of my craftman scrolling sabre saw and I can't get the part that is left inside out. Therefore I cannot put a new blade in. Is there a way to fix this?
Take off the clamp that holds the blade in place. Use a good degreaser (Electronics quality is best, it leaves no residue) and spray it into the blade holder. Next, blow it out with compressed air. The blade should be easily "bumped" out now. Oils & dust residue will hold the stub in, until you clean it out.
Oct 20, 2009 | Craftsman Saws
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Replacing saw blade
there is a spindle lock button between the handle and the blade housing, rotate the blade by hand while pushing in on the lock buttonwhen it goes in all the way the blade will be locked in position so you can loosen the bolt with a wrench
Mar 31, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Measuring Tools & Sensors Logo
206 people viewed this question
Top Craftsman Measuring Tools & Sensors Experts
Vuk B
rsuchowi
Level 1 Expert
S Sigs
S Sigs
Are you a Craftsman Measuring Tool and Sensor Expert? Answer questions, earn points and help others
