Question about Whirlpool ED5FTGX Side by Side Refrigerator
Water wont work for drinking
Nothing is coming out. It started slowing down, now nothing.
    President:
  • Whirlpool Master
  • 1,922 Answers
More than likely either your water line to the filter or the filter is plugged and needs repl., slightly loosen water line at each dide of filter and see where you start to get constant good water flow,then you've found the culprit
Posted on Jul 28, 2009
  • daniel  hendrickson
    daniel hendrickson Jul 28, 2009
    nothing is coming out. It started slowing down, now nothing
Ihave had Hiccups for two days and need a method of stopping so I can get some sleep
Hey there "Lanier" do you still have the Hiccups ? if so, I will tell you how to get rid of them in 30 seconds.
get a medium size glass (10-12oz) fill it to about 1" full from the top, now while standing up, drop your head down put the glass to your mouth so that your trying to drink off of the opposite side of the glass than you normally would, so that your chin is actually in the glass and so the bottom of the glass is going back towards your chest, now as you slowly bend forward from your waist, start drinking the water out of the glass, (its like your trying to take a drink in the opposite fashion that you normally would) . Now you might spill a little but its ok, you only need to drink a small amount of water, now when your bent over and have had a few swallows of water, keep your head bent down for 10 seconds or so and now stand back up and pour the rest of the water down the sink because your Hiccups are gone.
Here is why this works, (it's actually a biological plumbing thing) the " Hiccups " are nothing more than an air bubble in your digestive system, so by bending over and drinking the water in this fashion, it lets the water run into your system and the air bubble to escape over the top. ( BTW my dad taught me this trick in 1965 and I've cured a million cases of Hiccups, plus I've won a lot of money in the bars showing people how to do this ).
You can thank me later...
Sep 29, 2014 | Lanier UNKNOWN
Do drinking fountains easily infect one person with other peoples' contagious diseases?
When drinking fountains were first created they used to shoot "water one inch straight into the air, creating a bubbling texture, and the excess water" used to run "back down over the sides of the nozzle" (wikipedia) This was definitely an easy way to convey deseases. However, after a while, the production of drinking fountains started adopting an arc projection, which made it easier for the person to drink and made it more sanitary. Nowdays the jet of water goes as far as four inches in order to avoid infections and bacterial transmission.
Jul 03, 2013 | Water Dispensing & Filtration
What is a drinking fountain?
A drinking fountain, also called a water fountain or a bubbler, is a fountain designed to provide drinking water. It consists of a basin with either continuously running water or a tap. The drinker bends down to the stream of water and swallows water directly from the stream. Modern indoor drinking fountains may incorporate filters to remove impurities from the water and chillers to lower its temperature. Drinking fountains are usually found in public places, like schools, rest areas, libraries, and grocery stores. Many jurisdictions require drinking fountains to be wheelchair accessible (by sticking out horizontally from the wall), and to include an additional unit of a lower height for children and short adults.
How do you do the master cleanse?
The master cleanse requires ORGANIC cayenne pepper, ORGANIC lemons, ORGANIC maple syrup.( grade B.) Sea salt. ( the salt cannot be iodized salt. It has to be sea salt or himalayan rock salt from the health food store) You also need a laxative tea. ( a strong one ) For 10-30 days, you will eat nothing, drink nothing, except for lemonade that you make with purified water( 1 Litre) with the juice of 1 lemon, 1 tbs of maple syrup and cayenne to taste. You may drink unlimited amounts of lemonade daily.
Every night you drink your laxative tea. Every morning you make your salt water flush. 1 quart of warm water and 2 teaspoons of your sea salt. You drink this down and try not to ****. Do NOT leave the house. Stay near a toilet as this will produce an urgent bowel movement. Also, no store bought lemon juice as it contains chemicals and nitrates, you MUST use real lemons
Mar 30, 2012 | Health & Beauty
The machine says "ready"
That Sounds like theres a blockage, most likely limescale has built up in the boiler. If you try descale now when water is only dribbling through, it probably wont work. Recommend strip down machine and unblock pipework and try get water flow to come back stronger, then try a descale cycle.
Mar 29, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
Water keeps running from drinking spicket.
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip.
Aug 17, 2009 | Oasis P1AQ
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Drinking water from the door has slowed down alot.
check water pressure , it could be also a water valve problem , good luck
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool ED5FTGX Side by Side Refrigerator Logo
64 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
