Question about Kenmore 22422 Top Load Washer
Washer filles with water but wont change cycles
My washer filles with water and then ends up flooding the room because it wont switch over to the next cycle. I can do it manual but then it also sounds like at times that it bangs around while in its spin cycle. any solutions?
    Genius:
  • 1,122 Answers
Start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Posted on Jul 22, 2009
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
My Maytag Atlantis washer stopped working after moving?
maybe the hose came off the water level switch,,,just remove the screws in each end of the control panel,,some machines you have to remove the panel end caps to get to the screws,,,,then pull slightly forward and flip the panel back to access the level switch,,,,,,my hose came off 1 time and flooded the kitchen lol,,,,but air pressure coming through the clear plastic hose kicks off the water coming in and allows the timer to move forward to next cycle!
Apr 17, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore topload washing machine that wont switch to drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Then, see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Normally, this would appear to be a Lid Switch or Neutral Drain problem BUT since it is re-filling , it sounds like a Timer problem.
See the Service Manual for how to test / replace the timer.
Apr 16, 2010 | Kenmore Washing Machines
The cold water will not stop running during cycles
The load selecter switch has a hose hooked to it that tells the water when to shut off, hose could be plugged with soap, take off of load switch and blow out, if water is still not shutting off then replace load selecter switch, if still doesnt work the only other thing is the fill valve, tis is where water hoses are connected to on back off washer, you will need to replace, water sediment usually clogs it up.
Aug 23, 2009 | Maytag PAV2300 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
Water not shutting off to begin wash cycle flooded room
Probably one of the water cut off solenoids not shutting off.
Do you use both hot AND cold water?
Try using only cold water first. If that works, maybe hot water solenoid is faulty.
Next, connect cold water to the HOT inlet, and try it again. This means you have now tried each of the solenoids, and maybe identified which one is faulty (assuming thats the problem!). If water wont cut off after trying this, the problem will be with whatever level sensing device it has, but I am not familiar with the model you have, so cant help there. Good luck.
Jun 01, 2009 | Washing Machines
The washer doesn't stop filling and the agitator isn't working. The drain and spin cycles still work.
One of four things is happening...
1. Your drain hose is too low or is too far down the stand pipe and is causing water to siphon out of the machine
2. Your water inlet valve is stuck open and will need to be replaced.
3. The pressure switch (water level switch) has failed and won't switch between fill and wash.
Does it flood the room? If not probably #1.
Does the water stop running when you unplug the washer? If so, #3
Can you only stop the water flow by turning off the house hot and cold valves? If so, #2
4. If none of the above, then you might have a clogged pressure switch hose. It is a hose that connects to the water level switch (pressure switch) on the top end and the outer tub on the bottom end. It may have gunk plugging it up on the tub side preventing air pressure build up to trigger the water level switch. If so, remove the hose from the tub and clean out the end of the hose and the air dome that is attached to the tub. What brand is your machine?
Dec 19, 2008 | Roper Washing Machines
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
70 series Kenmore washer
POWERUP, YOUR WASHER COULD BE THE LID SWITCH OR THE COLD WATER VALVE. AT THE END OF THE WASH CYCLE, THE MOTOR WILL SPIN OUT THE WATER, BUT ONLY IF THE LID SWITCH IS ACTUATED. IF THE SWITCH IS BAD, IT WILL NOT SPIN OUT THE WATER AND THE TIMER WILL NOT ADVANCE FROM THAT POINT.
IF THE WASHER SPINS, THE NEXT STEP IS TO FILL WITH WATER FOR THE RINSE CYCLE. MOST WASHERS USE COLD WATER FOR RINSES. IF THE COLD WATER VALVE IS RESTRICTED OR FAULTY, THE WASHER WON'T FILL. IF THE WASHER WON'T FILL, THE WATER LEVEL SWITCH WON'T ACTIVATE AND THE TIMER WON'T ADVANCE TO THE NEXT STEP.
Mar 31, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
293 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
