I have been trying to set up the following combination for my brother.
JVC Digital Video Camera GR-DVL150
HS-V4Kit JLIP Video Capture software JLIP Video Producer software
PC Digital Photo lead 2.5mm 3-pole to 9 pin serial
We are not having any success, the PC does not 'see' the camera, I tested the serial port by doing a direct cable conection to my notebook, this worked fine)
I am not sure if the V4 kit is compatible, as the handbook says use a V16 kit, (but JVC told my brother the V4 kit is compatible)
Also he was told by JVC to buy the above lead, however I think he may need a JLIP 3.5mm 4-pole to 9 pin serial cable ?
If anyone can throw some light on this problem I would be very gratefull.
What is the difference between PC (digital Photo) and JLIP ?
-   need softaware to capture video from my camcorder not using fire wire or usb
-   madyembwa
Best Solution
posted on Aug 09, 2005
Mini Me - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Do you have the small docking station that originally came with the camcorder? I have the same set-up and the camcorder is placed on a docking station and has a turn-clamp to connect. The cable is then placed in the computer's com port. TIP: The camcorder must be in the docking station and powered up when I boot the computer to recognize the camcorder. It works well to capture photos from video. My worked on WIN 98 SE and WIN XP. Good Luck.
DAR
Was this helpful?
Yes
No
Solution #2
jessie25 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
I have a JVC GRDVX10 and I use the the "Card navigator" software that came on the CD to download still images via the serial port.
Was this helpful?
Yes
No
Solution #3
Reynolds - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
On 20 May 2002 04:52:26 -0700, mcd @yahoo.com (Dennis) wrote:
NT> The JLIP Video capture is a bit of a misnomer, it only captures still images. the Video Producer software allows for a certain amount of editing, you still have to output to a VCR or harddrive. IEEE (firewire card) is a better way to go.
Was this helpful?
Yes
No
Solution #4
Green1 - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
My brother does not have that software as his camera does not contain a memory card.
Dennis
Was this helpful?
Yes
No
Solution #5
kioner - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the info, my brother is only interested in capturing still images, however I can not get this combination of equipment I mentioned in my following post to work, I really need to know if it is compatible ?
Dennis
Was this helpful?
Yes
No
Solution #6
Odud - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
Not the answer you are looking for- but, the JLIP software is very crude compared to the many IEEE1394 DV / in / out programs available-
Studio 7, Vegas Video, a variety of offerings fron Ulead - - take your pick.
KP220 LG mobile. It had fallen from table at 1.5 mtrs height. from then signal reception is nil...
(More)
KP220 LG mobile. It had fallen from table at 1.5 mtrs height. from then signal reception is nil & often displays 'searching' the network.I have BSNL connection.Pl give solution
Hi I have the above video camera. I have a new Acer computer I have Vista home premium I have...
(More)
Hi I have the above video camera. I have a new Acer computer I have Vista home premium I have connected a new firewire cable Vista does not see the camera. I have tried the help advise on cable connection and camera mode etc. Nothing happens it just does not see the camera not even that the connection has been made I have no camera software it did not come with the camera when I bought it new some 4 yrs ago Any help would be great. Regards Pete
