Question about Samsung YP-K3 MP3 Player
Volume limit The settings section has no facility for overriding the volume level, help!!
  • 70 Answers
You may need to upgrade your firmware by visiting the samsung support website.
Posted on Jan 21, 2008
How can i increase the volume? Even at maximum level it is barely audible!
Look for a volume control in your settings section. Sometimes the settings volume is down & the app volume is a secondary control that can only go as high as the settings(or master) control, Turn it up and you regain control from the app you are running.
Aug 05, 2015 | Tablets & eReaders
How fix talkback in magnum delta force
you need to check the audio path from the chatback board to the audio circuit
usually the audio out the board will go to the center connection
on the volume control
sometimes people use a resistor to attenumate it to a level
or a T pad
and connect it to the left side {audio out to amp}
so a volume control works like this
left center right
ground audio into control audio to amp
so usually the center is used as the volume will track up as your sets volume is increased
so simply connect the audio out from the chatback
to the right audio to amp section
on the chatbacks ive made and installed in the past
had a small pot on the board
this allows the volume from it too be increased
so look for this first
if you cant find it you can make one up like this
100K log pot 3 pin
1 2 3
L M R {left middle right}
1= ground
2= audio from chatback
3= audio to the right right audio to amp on the cb's volume control
then no matter what level the actual audio from the set is set too
the chatback can be set to a standard level for all
hope this helps you
i used too build chatbacks for the rnid year back and fit them free
Dec 02, 2014 | Magnum DeltaForce CB Radio
My phon dosent have sound when it is ringing
1st thing to do is to slide you finger from the top of the screen to pull down the menu. There should be a section there that tells you if the phone is on vibrate or silent. If the phone is on loud try adjusting the ringer volume with the side volume buttons. if all else fails go in the setting in the sound section and check the volume levels that way.
Feb 23, 2014 | Samsung galaxy nexus
My TV, AKURA AODV211T-S, the on screen display is not showing ? Unable to see volume level, channel numbers, menu display ? There is no info in the Manual Instructions book.
The display driver section circuit should be troubleshooted. Contact any experienced service technician. It is a skilled work; not a user repairable one.
Mar 22, 2013 | Audiovox Televison & Video
Hello I can hardly hear on all of my channels. I have directv and I can't get a reasonable volume. Is there something I can do to fix this problem?
Directv low volume problem.
One sure way to eliminate Directv's low volume and any other volume problems in general is by installing a stereo compressor between your Directv receivers audio outputs and your TV's audio inputs. (Simply plug the compressor's outputs into TV and your receiver outputs into the compressor's inputs). By correctly setting the controls on the compressor, you won't loose the dynamic program content. Not only will it raise the volume level to where you want it be, it will also prevent it from exceeding any set level you chose, actually limiting how loud any sound can be. These settings are fully adjustable. In other words when you switch from Directv back to a dvd or any source, no more sound blasting, you can set levels to be the same now since you have raised then adjusted Directv's level to normal. Plus a compressor will raise those low hard to hear audio sections often found in movies. This is the reason we used them all the time in the recording industry. Another benefit is it levels all channels on Directv. The result, channels are now the same volume. This is what I'm doing to end the problem. Hope this helps someone. J Pynckel
Jul 27, 2010 | Directv H21 DTV Receiver
Everything works except the person I call cannot hear me. I am using skype. The echo check on skype works, I have tried two other cameras and I have the same problem. No matter how I change the settings...
The Camera and Audio setups are unrelated in both Windows and Skype. Please check your Windows Audio devices volume settings and specifically the Microphone settings: it appears to be disabled or the volume level set much too low. The windows settings overrides the settings in Skype (or in other words, Skype volume settings are a subset of the Windows volume settings). Check that Skype audio is setup properly after starting Skype: Tools -> Options -> Audio Settings -> select your required devices and volume levels. During this ajustment process, make free calls to Skype 'Echo / Sound Test Services".
Hope it helps! Let me know how you go!
Dec 31, 2009 | Microsoft LifeCam VX-5500 Webcam
The volume on my acer aspire 5532 is not very at maximum level
Go to Device Manager and up date your drivers if this don't fix the issue. Try removing the driver and visit http://www.acer.com/worldwide/selection.html select your location.
Visit the drivers download section and download a fresh driver.
Dec 26, 2009 | Acer Computers & Internet
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
How to vary the Multi zone levels at the receiver
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Jul 16, 2008 | Denon AVR-3802 Receiver
Durabrand CD Home Music System - Volume default
HM3817DTBLK:Default volume
I sent a note to the manufacturer. Communication attached below.
Dear Customer,
We thank you for your interest in GPX and our products. We apologize, but the volume level on the unit is a factory setting that we are not able to override or alter.
Once again, we apologize for any inconvenience this may have caused.
Best Regards,
GPX Consumer Service
>>> "Chris" 12/27/2008 2:02 ">x.x@eds.com> 12/27/2008 2:02 >> PM >>>
The default volume is set way too high on this radio. It is at 17 and we would like to reset it to a much lower level. How do I do this?
Chris
Jan 08, 2008 | Audio Players & Recorders
Samsung YP-K3 MP3 Player Logo
112 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
