Question about Pure Digital Flip Video Ultra Camcorder
Flip Ultra - freezes at initial Flip screen - will not shut off
Camera worked great until the batteries were removed for several months. New batteries installed- would not reboot beyond intial Flip screen. Customer Service advised - remove battieries, wait 72 hrs try again. Worked until it was turned off - then froze at same spot when reactivated. Everything works well when plugged into USB post. Customer Service response - no longer under warranty!
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Posted on Aug 12, 2009
  • sunsetcruise
    sunsetcruise May 10, 2012
    Didn't have it more than a week before it shot. (And yeah, it's been a few years since I've had it, but ********* I want it to be fixed...!)
    That fix doesn't work for my non-HD Mino. Also tried the "reset" button that is supposedly inside the tripod jack??? Can't find any solutions.
    Cannot believe I ever wasted time or money on this POS.
Thanks so much...my Flip is back. But still have a color shadow on screen making a weird sound noise. Help.
Posted on Aug 24, 2009
FLIP Ultra model U1120 will appear to power on (ie startup screen will flash on for a second) then power off. If I connect to USB it will cycle thru this on/off about a second each. PC will not ID FLIP...
This may sound like a stupid question, but did you make sure your rechargeable battery pack is installed??? if they are in there I would try removing and check connections to make sure they are clean and no dirt and then try reseating the battery pack again. if no battery try installing AA batteries, my model U2120 takes those also if you are new to this camera, there is a little dial at bottom of camcorder to unlock the front cover, turn to unlock and the front of the camera slides off to show the battery compartment. maybe the rechargeable battery pack is shot and won't charge so try the regular batteries whatever kind yours takes. good luck!
Sep 09, 2011 | Pure Digital Flip Video Ultra Camcorder
Flip Video Ultra Camcorder: After I downloaded my last videos my camera stoppe...
Remove the battery. Connect the camcorder to the computer's USB port. The computer will show the autostart menu or give a beep. Insert the battery now. Use the 'Safely Remove Hardware' option, stop the device and remove the Camcorder from the Computer. Close the battery compartment. Bingo! The device works :-)
May 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
My flip video won't turn off or record, won't be acknowledged by PC via USB port - seems to have frozen - screen is black but light behind it showing power is on but can't do anything with it.
To fix, I held the on/off button down for an extended time (around 10 secs approx) until it finally turned off. Left it alone for a few minutes and then turned back on. Worked okay. Also got a response from flipshare support who said there is a reset button inside the tripod space, use a pin to press that and then fully recharge camera via USB slot on PC.
Jan 12, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip video freezes when I turn it on to record
If the camera2_bing.giffreezes, and if it freezes more frequently and you experience decreasingbattery runtime, you may need a battery replacement. If battery replacement doesn't cure it you need a new motherboard.There is a servicethat can fix common issues like the battery screen, on Flip VideoCameras Flip Video Repair
Jan 01, 2010 | Pure Digital Flip Video Ultra Camcorder
Stuck on Flip Video logo when I turn it on & can't turn off!
Yes this can sometimes happen if the camera2_bing.giffreezes. Use the reset button to recover it from this state. If it freezes more frequently and you experience decreasingbattery runtime, you may need a battery replacement. There is a servicethat can fix common issues like the battery screen, on Flip VideoCameras Flip Video Repair
Dec 29, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video mino troubleshooting freeze
There is a reset button! Get a pin and push into the tiny hole at the bottom - inside the tripod screw hole. Push in and hold. The camera will reset. I called the Flip support - they were great !
Apr 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Pure Digital Flip Video Ultra Camcorder Logo
1,311 people viewed this question
Top Pure Digital Video Cameras Experts
Ron Dufek
Ron Dufek
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
