Question about ASUS P4SP-MX Motherboard
Same problem as well
Any reboot results in several bios beeps similar to what's described above. After powered off for 30-60 minutes the system will POST and some bios settings need to be set, such as CPU speed and absence of the floppy drive. System will then reboot fine.
However, any reboot requires a 30-60 minute cooldown even if it has only been up for a few minutes.
It's running with the case open, and I just replaced the PSU. Have previously replaced the battery, as it looked like the battery was dead since it seemed to lose its bios settings.
    Problem Solver:
  • 17 Answers
Check this site for bios beep codes... http://www.5starsupport.com/info/beep_codes.htm
I would also check on your computer temperature, the cpu, graphics card and motherboard temp... make sure they dont overheat. temp differs for each component so just research the manufacturer and recommended temps for your computer
Posted on Jul 21, 2009
My Acer ES1-512 model no.MS2394 fell over in its carrier case on carpet. went to turn it on & the screen is black & says no bootable device. What do I do? I can't get the back off to check hard drive.
Have you tried to unplug and then reboot after several minutes? Usually Hd will survive a fall on carpet. It may be that It needs to Have the bios checked and updated. I recently had several power spikes and inspite of a power supply with Serge protection, the next day I had similar issues. Had to "set up bios again".
May 04, 2015 | Acer Computers & Internet
What keys do I press to access the bios
when you boot your computer 'del' 'f5' 'f2' one of the 3 keys will take you to the bios depending on the computer you have
on start up you will see 'f2' to enter setup (or any of the keys above) you can only see it for a sec or 2 that is the time you must press it to go into the bios setup
Oct 01, 2014 | Toshiba Satellite L955-S5362 Notebook...
Bios Beep
Motherboard BIOS Recovery Jumper
  • Install the bootable BIOS upgrade disk which you previously created to do the original flash upgrade into drive A: and restart the system. If the update failed because you used the wrong BIOS update you should get the correct one and repeat this step. When the computer reboots there will most likely be no video prompts, however you can monitor this procedure using the floppy drive light and the PC speaker. When the PC speaker beeps and the floppy drive light is lit it means that it is currently copying the new BIOS onto the motherboard.
  • When the floppy drive light goes off and the PC speaker beeps (twice in most cases) the recovery should be complete. During the update procedure there might be pauses that looks like your computer is doing nothing, if so be sure to wait at least a minute to make sure the update is complete. When you are sure the BIOS update is complete and there is no more activity, power off the computer.
  • Change the jumper you changed before back into the original position so the computer can operate normally.
When you turn your computer back on your BIOS will be functional and you should be able to use your computer normally again.
Apr 30, 2012 | Acer VL460-UD4500C WINDOWS VISTA BUSINESS...
Cpu fan works, power supply fan works why wont' computer come on?
Could be a number of reasons:
The CPu fan and the PSU fans will come on, even though the system is not working. There is a possibility that the CPU has blown, you can check this easily by (carefully) feeling the heatsink after it has been running a while. A dead CPU will not use power and therefore not heat up. If after say 10 minutes of running, the heatsink is clay cold, suspect the CPU. Replace with another one, spreading CPU grease on the top before putting the heatsink back on.
A blown CPU will usually be indicated bu there being NO beeps from the system (see below)
If the CPU appears to be generating heat, visually inspect the board, look for blown or blowing capacitors (the small cylinder like components) on the motherboard, any that are bulging or leaking a brown residue, or have blown, will render the motherboard inoperative.
If these appear ok (they still may be damaged), unplug all components except the hard drive, and ram and video card, see if the system then boots. If it does, proceed to re-installation of each in turn, until the faulty peripheral halts the boot.
Listen for any beeps as the ssytem switches on these beeps describe the type of problem
(repost if you hear any beeps)
Remove one stick of ram and try rebooting, if it works, suspect the ram module, try the other and see if that makes any difference.
Failing that, your last recourse is to power the system off, remove the bios battery, replace after 2 minutes and see if clearing the Cmos "unsticks" the computer.
After That, suspect the motherboard is dead.
Apr 25, 2011 | Computers & Internet
How do i reset a bios on my laptop
If your model is fairly new:
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
Otherwise press ESC quickly after it comes on, and then it will show somewhere "press XXX for setup" or similar
When you are in the BIOS, then there should be an entry somewhere that says "reset to system defaults" or "reset factory defaults" or "reset optimal" or similar. Do that, then reboot. Bios will be reset.
Nov 30, 2010 | Toshiba Computers & Internet
My Vaio wont start- I have tried rebooting a few times and its not working. What can I do?
That you have rebooted the desktop several times is indicative of your computer ability to power on. However, you are probably not able to load windows. There are several issues that can yield this result. 1. Windows is corrupt and needs to be reinstalled 2. The boot order in the system BIOS is set incorrectly 3. Your Memory Chips are bad 4. Your processor has died. 5. Your video card or onboard Graphic chip is bad. 6. The capacitor that regulates the power to the onboard graphic chip is bad. Any of the above can yield the result you are confronting.
Enjoy the power of a PC.
Mar 15, 2010 | Sony Computers & Internet
System has been working fine for several years. Now on boot up, shows initial screen with ASUS information (motherboard model P5N32-SLI SE Deluxe, Press DEL to run Setup). No BIOS beeps. Warm reboot,...
Are you able to enter into the BIOS settings by pressing DEL?
If so, load default settings in the BIOS and try booting up again.
Best wishes,
Graemevm
May 05, 2009 | ASUS AI Lifestyle P5N32-E SLI...
I have a Dell PowerEdge 1500SC that is powering off
usually this would mean the process is overheating or bad,tell me this do you hear beep codes 1 1 2 indicate processor failure.So reboot and pay attention to the beeps repost and i will try to help you further.
Good luck
Apr 07, 2009 | Dell PowerEdge 1500SC...
Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Mar 11, 2009 | Dell Computers & Internet
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
ASUS P4SP-MX Motherboard Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
