Question about ASUS P5S800-VM Motherboard
ASUS P5S8000-VM/S no bios screen no beeps
I have removed all cards hard drives memory and processor leaving just power,keyboard,mouse and monitor connected will not boot into bios or show any screen or beep.
Purchased another board but does same replaced power supply but still no screen or beeps
    Brigadier General:
  • 7,191 Answers
From the description of the problem, it seems that either the power switch of your PC or the power supply cable is faulty. Also, please let us know if the motherboard LED is glowing or not. Do reply for more assistance.
Thanks.
Posted on Jul 21, 2009
My compaq presario sr1103wm doesn't boot up it
First of all.. try connecting all your peripheals to your PC.(monitor, mouse,keyboard,mic,speakers,etc)
Then u should open your pc and remove BIOS battery and leave it out for few minutes and put it back in...
if that doesnt work u should remove all your RAMS (memory chips next to processor) carefully and start your PC without them, u should hear some beeps, that okay, just a warning, after that put them back in and start again.
if that doesnt work try changing your hard drive with another one, or just take yours and test it somewhere else.
the last u should check your power supply, i see it starts up and then shuts down.. if your power supply is dead u couldnt even start PC, maybe there is a problem with your power outlet, try changing cables and outlets, if still doesnt work test your power supply on other PC.
if none of this works then u probably have issues with motherboard or processor.. then you should take it to service
:D
Feb 16, 2013 | Computers & Internet
How to build a or assemble a computer and troubleshoot?
Building a computer will require: a motherboard, a processor, memory, a video card or motherboard with onboard video, a sound card or motherboard with onboard sound, at least one hard drive, a CD or DVD drive, a case for the computer components, a power supply, fans to cool the computer, an operating system, a monitor, speakers, keyboard, mouse, 2-3 hours to assemble the computer.
You must ensure that all of the components are compatible with one another. After receiving the parts, lay everything out on a large, clean surface. Make sure you are grounded by touching a metal surface; this will prevent the transfer of static electricity to your computer components.
Typically, the steps to install the components are as follows: 1. mount the power supply in the case, 2. mount the motherboard 3. lock the processor in the socket on the motherboard 4. insert the memory sticks into the slots on the motherboard 5. mount the processor fan on the processor 6. insert the video card into the applicable slot on the motherboard 7. insert the hard drive into a hard drive bay in the case, 8. insert the CD drive into a CD drive bay, 9. mount any fans you have to the fan cutouts on the case 10. connect all applicable data cables to the CD and hard drives 11. connect all applicable power cables to the motherboard, video card, processor, hard drive, CD drive, and any other components. 12. connect the front panel USB, power, lights, and reset connectors to the motherboard 13. close the case 14. connect the power, monitor, speakers, keyboard, and mouse to the computer
Because this process is rather involved, I recommend following a guide such as this one: http://www.maximumpc.com/article/how-tos/how-_build_silent_gaming_pc
It details the process, includes pictures, and even provides a list of compatible parts.
Jun 19, 2011 | Computers & Internet
Does not boot
To exclude a possible short, remove the MB from the case and place MB on to a couple phone books thats covered with a non static MB bag. Connect power supply, keyboard, mouse, primary hard disk drive, monitor and internal speaker. Also leaving CPU/heatsink assembly and memory connected.
Short the power-on pins by using a pen. See page
1-34 in you're manual, PWR BTN. If the system boots ok than there was a short with the MB while in the case. If the system does not boot than the MB is bad or the bios needs flashed. Keep the MB out of the case and follow the instructions on page 2-2 section 2.1.1
Link to Asus; http://usa.asus.com/Search.aspx?SearchKey=P5RD1-VM
Hope you find this helpful!
Mike
May 08, 2010 | ASUS P5RD1-VM Motherboard
A display problem in my Acer desktop pc
techguru 2009: First thing disconnect all power. Remove all drives (hard drive, CD/DVD, Floppy). Then remove all PCI cards. Also slowly remove the Memory cards. You should only have the motherboard w/processor and the power supply connected, do not connect the monitor or mouse\keyboard. If you have a CMOS battery also remove it. Careful turn the power on, you should hear several beeps. That is letting you know that there is no memory installed. Turn power off disconnect power cord. Slowly install the memory cards, keyboard, mouse, monitor. If you have a pci video card install it now. Turn power on. you should see the bios loading then error message there is no disk or operating syste. turn power off and start connecting one device at a time so your bios can recognize it. This should let you know if you have faulty hardwareby isolating each install. If you still have problems let me know.
Jan 30, 2009 | AcerPower FV PC Desktop
WINDOWS XP PRO SERVICE PACK 3
First off, please use proper case. All upper case makes it look like you are shouting. Thanks.
Try removing everything you can possibly remove from the outside other than the monitor. Remove any cards inside not needed to boot (sound, NIC, modem, etc.).
Disconnect mouse and keyboard, too if it will boot without a keyboard. Some systems will halt at the BIOS screen without a keyboard.
When you have a minimum config for booting, boot and see if it stays on. If so, one of the items disconnected is the culprit.
If not, reconnect keyboard (if disconnected) and boot into Safe mode by tapping F8 after BIOS screen. See if it will stay on in safe mode. If it will stay on in safe mode, problem is O/S.
If it won't stay on in safe mode, see how long it will stay on at the BIOS screen. If it will stay on indefinitely, you could have flaky RAM or possibly hard drive. Power off, unplug power cable, remove hard drive and see if you can boot to the Windows CD. If it will boot up to Starting Windows and stay on, probably not RAM although that is not a definitive test. At that point, I'd try another hard drive and see if the O/S will install or try wiping and reloading the original hard drive.
Let me know if you need more help.
Honest1abe
Jan 17, 2009 | SuperMicro Pentium III Xeon (TMR-004)...
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
The best thing to do in this situation is to build your machine outside of the case, using the minimum amount of hardware,
Remove the motherboard and using only one stick of ram, the monitor, keyboard and mouse. short the power switch connector on the motherboard with a screw driver for a fraction of a second just to power it on.
If it starts up and gives you a "no boot disk" or "no Operating System found" at least you will know it's working and you can slowly connect everything else one by one to see whats preventing it from booting.
If it doesn't start like that, remove the power cord from the power supply and remove the mother board battery for at least 15 minutes, this will clear the BIOS and set it back to factory spec, now carryout the out of case procedure already stated.
Jul 22, 2008 | Intel Motherboard
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Monitor says
Try and kill the bios. Find the jumper next to the battery on the motherboard and move it from position 1-2 to 2-3 ... press the power button a few times. then put the jumper back to normal and give it a shot.
I would disconnect the cables first before anything and attempt to boot the system.. if it boots, then start plugging hte cables one after another until you find out what's causing the machine not starting correctly.
Good luck.
Jun 15, 2008 | Computers & Internet
Processor issue? bios/motherboard?
First, Pull the hard drive. If the hard drive shorts out it can cause all sorts of problems. Generally it detects Hdd before mouse and keyboard.
Apr 18, 2008 | Averatec 3200 Notebook
Boot
Do any lights turn on when you power it on? Can you here the fans spinning and hard disk working?
Sep 14, 2007 | Computers & Internet
ASUS P5S800-VM Motherboard Logo
968 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
