Question about Samsung SGH-L700 Cell Phone
How to install games in samsung star S5233 - Samsung SGH-L700 Cell Phone
  • Anonymous Mar 23, 2014
    memory not working
  • Samsung Master
  • 1,511 Answers
The previous one was good.....but instead you can use tk file explorer to update the contents in the game folder. Just connect s5233 to PC. First time you should be prompted with a 'device installed and ready' message.
Execute TkFileExplorer_2.2.exe
Go to Settings - COM.
Scroll down Port window: You should get just one COMxx option. Choose it and press OK.
Go to File - Connect. You should get the F480 File System Tree at TkFileExplorer bottom half side.
Go to /Exe/Java/Games
Create a New Folder for your game
At TkFileExplorer PC upper side select game JAD/JAR files and copy to s5233 created folder using drag&drop or right button menu Download option.
Repeat steps 9 & 10 for all games you want to install at a time.
Disconnect USB cable
Dial *#6984125*#
Go to Internals (Master Key: *#9072641*#)
Go to Storage Settings and select Update Java DB
In the previous one you needed gprs, in this one you do not...
And remember to download " .jad file " for you game/app (You can fine tons of free games/apps form GetJar )
If i was helpful, kindly do Rate!
Posted on Jul 21, 2009
  • Waqar Hassan
    Waqar Hassan Jul 21, 2009
    With Step 9 i mean from "Create a new folder for your game" :-)
I go to TkFileExplorer_2.2 and theres on ports there to select
Posted on Sep 24, 2009
I have s5233, when I run TkFileExplorer_2.2.exe then when I go to settings then click COM then The 'Port' field is empty... What should I do? please help.
Posted on Feb 02, 2010
The simplest way I found is,
a) Goto http://rumkin.com/tools/sprint/
b) Upload the games you have (jar format is sufficient. No need of .jad file) in Upload Games section.
c) Upload code will be generated. Make a note of it.
d) Through mobile browser goto http://rumkin.com/tools/sprint/jump.php
e) Enter the code, click on Get file, install and enjoy.
If you don't have games goto http://www.dotsis.com/mobile_phone/showthread.php?t=196083
Posted on Dec 31, 2009
When i connect my mobile to the pc i choose option pc studio. but when i run tkfileexplore_2.2.exe then i go to stettings the click COM the'Port' field is empty... What should I do? please help.
Posted on Apr 02, 2010
  • 4 Answers
If TkfileExplorer is not working and Lite FTP is annoying with ads, please use this method.
http://ckarthik17.blogspot.com/2009/...-games-in.html
Posted on Dec 24, 2009
I have s5233, when I run TkFileExplorer_2.2.exe then when I go to settings then click COM then The 'Port' field is empty... What should I do? please help..
Posted on Dec 23, 2009
Download jar games through ur gprs
it will not accept jar games through ur computer
it only supports jar files with midp 2.0
Posted on Aug 19, 2009
MY MOBILE SAMSUNG STAR S5233
I HAVE A PROBLEM IN TkFileExplorer_2.2.exe THIS SOFTWARE , I USE IT AND WORKING OK,
BUT WHEN I UPLOAD JAD & JAR FILE ..... I FACE SAME ERROR MASSAGE .
I COPY GAMES TO OTHER SAMSUNG MOBILE TO MY MOBILE I HAVE SAME PROBLEM AND HANG COMPUTER
PLZ......... GIVE ME ANOTHER SOFTWARE OF THIS WORK.
AJITSINGHPANWAR@HOTMAIL.COM
Posted on Nov 05, 2009
Hey ckarthik17
this very nice trick i have every seen.
its really work for me
thank u very very much bro.
Posted on Feb 04, 2010
Helloo every .dis razz... c no need to installl tk fle xplorer...dats all time taking stufff... s guyzz tak here a tip ... first of all ...wat shud u do iz update ur mobile with firmware .... which is the perfect solution is,,,,so kindly update ur firmware...the name of it is s5230xeii4...after dat ,,u can enjoy ...if u hav any doubts ,,,kindly add me as ur fren in orkut ..ill help u in online...sighning off --razz
Posted on Jan 06, 2010
    New Friend:
S5233 hardreset
Posted on Jul 04, 2013
i just want to check if there is any software for my samsung star handset, Where i can go to the menu screen while im on call
Posted on Sep 26, 2010
If no port is showing you can start by typing in "COM1" till you get it right. mine works in "COM5". Hope this works for you now.
Posted on Aug 04, 2010
I have the solution visit this site for how install games, landscape touch games and wallpapers with three images. http://downloadsamsungstarwallpaper.blogspot.com/p/how-to.html
Posted on Jun 07, 2010
Can some body help
cuse wnever i download .jar file with tk explorer
it shows eror report
Posted on May 21, 2010
Which is the game side available for Samsung S5233A
Posted on May 05, 2010
I have used samsung s5233w pls how to install new games let me knew and which mobile site can i use
Posted on Apr 24, 2010
Ckarthik17 i followed all d steps as u mentioned.. But in my games folder i wsnt able to see new games?? no new game is added out dere in my games nd more after d last step.. WHY??
Posted on Apr 18, 2010
How can we transfer the samsung star games through our pc
Posted on Apr 01, 2010
Hi have samsung star s5233s
SOURCE: How to install games on samsung star s5233...
go to more games from ur mobile's internal inbuilt link in games.
Posted on May 25, 2010
skdeepak88
  • 232 Answers
SOURCE: How to install games in samsung star S5233
Detailed Guide on installing Games and Apps for S5233/S5230
(Note: Tried it myself many time. Works perfectly).
I am assuming you have the game you want to install with you. In this example I downloaded Erix.jar game. And created jad file using JADMaker (Google for JadMaker, to download it). Using JADMaker you need to create ".jad" file. Now I have "Erix.jad" and "Erix.jar" files.
Connect the phone to PC and start "Samsung New PC Studio"
Open the File browser and go to "External Memory". Create a directory there (Name it anything you want your game name to be).
I will be creating a directory called "Erix". Then copy the Erix.jar and Erix.jad files into that folder. Disconnect the phone from PC now.
Got to Menu -> Browse -> Enter URL
Type -> "http://m.GetJar.com"
Browse down and you will see "Quick Download". Click it. Then enter quick download code as 51799 . Download and install it. Exit from browse.
Go to Menu -> Applications -> Games and more -> LiteFTP
You will be in LiteFTP menu
Select Mmc (Memory card) and click OK. It will be at end.
You should be able to see the folders in memory card. Select Erix folder (dont enter it) and press "123" button. Then press "1" (This will copy the Erix folder). Select "Back". You should be back in "root" directory.
In root directory you will see a folder with "dont enter" symbol named "My PrivateMy PhotoMy Video .......". Select it and press OK to enter it.
There will be nothing in the folder. Now paste the Erix folder. To do so press "3" to paste.
Exit the LiteFTP.
Open "Keypad" and type "*#6984125*#" (Without quotes)
This will automatically open "Admin setting"
Select "4 Internals" and enter "*#9072641*#" (without quotes). And confirm.
This will take you to "Internals" menu. Select "6 Storage settings".
Select "2 Update media database"
then select "3 Update Java DB"
then select "10 Create Ax Dat File"
Exit from all those menus.
Now go to Menu -> Applications -> "Games and more" You should be able to see new icon "LiteFTP/files/Erix". Rename it if you want to. Then start the game.
All Games and Software's installed in this way will be located in Menu -> Applications -> "Games and more"
Rate this if you find it useful!!
Posted on Aug 22, 2009
KreativeGeek
  • 212 Answers
SOURCE: how do i disable keypad tones on a samsung star
Under Main Menu select -> Settings -> select phone profiles -> select normal profile by pressing the >> icon against it -> while on this screen on the top you would see a drop down list with following options "Incoming" "New Messages" "Phone Sounds", select "Phone Sounds" and slide phone sound volume to 0 value and save your profile
Posted on Nov 25, 2009
  • 72 Answers
SOURCE: i cant install games in my samsung star s5233
Hi! If you can't install games in your Samsung Star, please make sure that the files are in .jad or .jar format. Hope this helps.
Posted on Feb 21, 2010
  • 40 Answers
DOWNLOAD MINI OPERA THROUGH GETJAR.COM SITE THROUGH YOUR MOBILE AND THEN DOWNLOAD GAME
Posted on Jul 26, 2010
Software not install for samsung mobile why????
HI...
Your samsung star is based on Java Operating System, so u can install only java themes or games. U can,t install the third party software bcoz java dosn't support it.
Jan 27, 2011 | Samsung Star GT-S5233 Cell Phone
I have't install games in my samsung s5233
you could begin from here. even when you browse or google, you may get links to a couple of free games for your mobile.
regards
Dec 15, 2010 | Samsung Star GT-S5233 Cell Phone
How to install games in samsung star??
how we can instal externel software/app...
Aug 12, 2010 | Samsung Star GT-S5233 Cell Phone
May 20, 2010 | Samsung SGH-L700 Cell Phone
How can I install java game in my samsung s5233 star
http://digitalconqurer.com/gadgets/samsung/how-to-install-java-appsgames-in-samsung-star-3g-s5603s5600/
Check out this tutorial above.
www.software112.com/.../java+games+for+samsung+s5233+star.html - 9 hours ago
Games above,How to's below.
http://www.mobilesheep.com/samsung/how-to-install-games-softwares-in-samsung-star-s5233-or-s5230
http://www.google.co.nz/search?sourceid=chrome&ie=UTF-8&q=how+can+I+install+java+game+in+my+samsung+s5233+star
Right click above link, and Open in new tab, there are many sites to now choose from.
Apr 14, 2010 | Samsung SGH-L700 Cell Phone
I bought a samsung star but i can't install software and games
Hi there! When installing software and games in samsung star, please make sure that the apps are in .jad or .jar format. Once you've checked that you have the correct format, please transfer the files to your phone using Mass Storage, after that, please open the application and then it will automatically ask you to install it. :)
Feb 20, 2010 | Samsung Star GT-S5233 Cell Phone
Java games are not supported by samsung star mobile
samsung star supports java games.. make sure that you're installing the correct file.. it supports, .jar and .jad formats.. :)
Feb 07, 2010 | Samsung Star GT-S5233 Cell Phone
I cant install games in my samsung star s5233 mobile. please help me.
Oct 10, 2009 | Samsung Star GT-S5233 Cell Phone
Samsung SGH-L700 Cell Phone Logo
25,913 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
