Question about Refrigerators
The freezer door will shut, but then it will slightly open.
    Champion:
  • 363 Answers
Clean all seals around door, and all contact points on door, this should help seal it tighter
Posted on Jul 22, 2009
Bottom freezer door pops open when you shut the top refrigerator door
See if you can adjust the front legs where it will have a slight backwards tilt, sometimes that works.
Jan 24, 2013 | GE Refrigerator. 20.3 cu. ft. 30 in. Wide...
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
My LG refrigerator (LRTN 19320WW) top freezer door ajar when the bottom cooler door closes. I think there is a connecting air tunnel between the freezer and cooler section that when the cooler is shut,...
The doors have tabs that push on the switches that turn the light off when the doors are closed. These doors have not been installed properly. I fixed the problem by shimming the bottom door up using washer at the lower hinge rod. Or yo can tape a bit of plastic to the tab on your door so that it makes good contact with the light swutch.
Sep 19, 2010 | LG LRTN19320 Top Freezer Refrigerator
My freezer door pops open when i shut the fridge door
make sure the fridge is tilted back a little so doors close with a little push by raising the front legs,also put some weight on the door, fill a bottle with water or any kind of heavy thing you want,this will hold the freezer door in place when you shut the fridge door
Dec 05, 2009 | Refrigerators
Freezer door opens when you shut the refrigerator door
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Sep 03, 2009 | Amana Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE fridge doors open and close
Raise the legs up on front till the machine tilts slightly towards the wall. The weight of the doors will then be shifted towards the machine instead of away from it. Only a slight adjustment is needed and should have been done by the delivery guys. A $5 tip would have gotten that done, you must be a cheapskate.
Source: I used to deliver them before I learned how to fix them. LOL
Mar 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer side door opens when large refrgerator door is closed
no promblem when you shut one door it forces air to the other side remove the kick plate at the bottom adjust the rollers till the fridge leans back i set them so when you turn loose of the door slightly past the halfway position it shuts its self that way when it pops open it shuts its self
Feb 15, 2009 | Maytag MSD2454G Side by Side Refrigerator
Amana 22 side-by-side refrigerator, freezer door opens slightly
There are three possibilities to this problem:
1. Door seal which should be magnetic is faulty.
2. Ice maker caddy (container) has not socketed properly into ice maker rear drive tang.
3. Door stay closed plastic hing pieces are damaged. These are tapered pieces that fit in hinge area that allow door weight to help close and hold door. Some are black in color and some are white. As far as I know they are interchangeable.
Jul 17, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
