Question about Dell 3010cn Laser Printer
THERE IS A BLACK LINE THAT RUNS DOWN THE PAPER ON THE LEFT SIDE. COULD IT BE THE DRUM? I HAVE A CHANGE DRUM SOON MESSAGE SHOW UP.
    President:
  • 2,306 Answers
If you look at the old drum, open the shutter, if you see that line on the drum, then it's a bad drum. The line could also come from the fuser roller...
Posted on Jul 21, 2009
I get a black line down the left side of the page when a document is printed
Either the black cartridge is bad or the fuser roller is bad. Pull out the black cartridge and gently pull down the flap that runs across the cartridge. Look at the drum inside. If you don't see a line running around the drum or a clump of toner on the drum where the black line appears on the paper, your problem is a bad fuser.
Aug 05, 2011 | HP Laserjet Cp2025n Printer
Leaving a wide black line in right hand side of transaction
Pop open the fax document feeder, and look for a glass strip about 1cm wide, that runs from left to right across the machine.
You will probably see a few spots of dirt, or more commonly, a blob of white liquid paper stuck on the glass, on the side of the machine that corresponds to the black lines on your fax.
Clean this glass strip gently, using a soft cloth dampened with a mild detergent. I often use diluted windex. You may need to scrape liquid paper gently with your fingernail. Close the cover.
Next, put a blank sheet into the feeder and make a copy of the blank page. If you have cleaned it properly, the copy will be blank as well. If you still have a line, align it with the feeder and use this as a guide to show you where the glass may still have some **** stuck on it.
Dec 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Message reading change drum soon permanently on screen. changed the drum as no printing could be seen, ie paper blank. however, still got the change drum message on the screen. how do i get rid of this?
7 Wait until the time, date and answering mode appear on the display. Then press the SELECT FUNCTION key. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 8 Press the 7/COUNTER DISPLAY One-Touch key. The display will show DRUM COUNT. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 9 Press 2.413c?openelement&fieldelemformat=gif to clear the image drum unit
counter. ecblank.gif ecblank.gif ecblank.gif ecblank.gif 10 Press the SELECT FUNCTION key to finish. ecblank.gif
Dec 03, 2009 | OKIFAX 4500 Plain Paper LED Fax
I replaced toner and drum. Still get change drum soon and now I get a black line at the left edge of the paper
You have to reset the counter. Stop a print or copy job with the paper still in the unit and see where the line comes from, ie fuser transfer etc.
Jun 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
Solid black line at the left side of paper after reset the drum
Try moving the blue panel to clean the drum after you install the toner.
plus before you do that, you need to clean up your drum by using the duster.
May 18, 2009 | Brother HL-2070N Laser Printer
Canon 4050 copier has line down the paper. How do I get rid of it
take out toner and shake it to clean the toner cartridge
or you need a new drum
Apr 16, 2009 | Canon NP 6050 Copier
Black Line on Side of Paper
Did you install a GENUINE Brother drum. I believe instructions are included with a new drum.
As far as the line goes......open the document feeder by pulling it open and look for wite-out on the scanner glass.
Also there should be a blue "slider" on top of the drum unit to clean the charge wire.
Oct 06, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Dell 3010cn Laser Printer Logo
160 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
