SOURCE: Charger Repair for Ryobi drill 14.4 volt
It has been my experience that when one component of a board goes bad that something else is wrong and even replacing that part still will not work. But you can try contacting Ryobi direct at their website and see if their tech service can get that for you. They are very vague when it comes to some of their products so good luck. Also as a thought if you have a tool repair facility in your area you might contact them and see if they have a junk charger laying around that you can scavenge for parts.
SOURCE: Missing fuse in RYOBI CTH1202 Charger.What size fuse .5,1.0 2.0 ?
that would be a 2.5 amp fuse , sincerely glenn
SOURCE: ryobi 18 volt battery charger
If replacing the charger is not an option, open it up and check the fuse. Another item to check is the current limiting resistor, color coded red-red-black.
SOURCE: will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
SOURCE: Who rebuilds ryobi 18 volt li ion batteries
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
