Question about Aprilaire 550 Humidifier
Aprilaire 550 humidifier
I sent my husband to get a new filter for an aprilaire 550 filter. He took the frame the filter sits in and everything attached. He threw the hole thing away. What parts do we need to put this back together without haveing to put a new system in.
You can call 1-800-955-7075 give them the make and model #.The part # should be 4217,10x113/8 frame for $14.56 plus shipping
Posted on Nov 21, 2007
How is the cover to the 550 Humidifier removed to replace the filter? elkandnlk@yahoo.com
The side opposite of the pipe inlet has a finger tip recess 1 1/2" from fron and runs vertical. Pull straight out
May 08, 2010 | Aprilaire 550 Humidifier
What controls how much water flows into an Aprilaire 550? It was fine until a couple of days ago. I replaced filter, but it still appears to be too strong. It not only runs out the drain tube but is...
In the water line where it connects to the solenoid is an orifice. You can install a smaller plastic orifice or you can install a manual feed valve to where you can control the flow.
Feb 12, 2010 | Aprilaire 550 Humidifier
Hissing sound
that is normal if it is too loud the filter inside may be dirty and need replaced they need replaced ever heating season
Oct 21, 2009 | Aprilaire 550 Humidifier
Low or no humidity.
i have an aprilaire model 550 im getting no water to the filter but i am getting water to the solenoid
May 11, 2009 | Aprilaire 550 Humidifier
Have solenoid: MOPD 125, WATT 2.3, VOLT 24/60, for Aprilaire 560 Humidifier. With a M15 Universal tester using 150mA for + & K OHMS FOR -, I get 2 ohms on scale which would be approx 200 ohms. Ohms = Volts...
I am guessing you have sent 24 volts to the solenoid directly and the the solenoid did not activate?
If you have not send power directly
If the solenoid does not activate that way more then likely needs a new solenoid.
Mar 05, 2009 | Aprilaire 550 Humidifier
It has been awhile since i removed my water pad and forgot how to route water line in pad
I've got a 560A, but if it's similar:  The pad sits in a plastic frame with the drain hole and "funnel" at the bottom.  At the top of the frame, there's a plastic piece that sits at the top of the pad; it snaps into the frame and the frame snaps into the humidifier housing.  The water tube from the solenoid slides into this plastic piece so that the water is directed to the top of the pad.
Dec 10, 2008 | Aprilaire 550 Humidifier
Water leak
your drain pipe is clogged up, going to drain- Duh
Jan 13, 2008 | Aprilaire 550 Humidifier
Aprilaire 550 Humidifier Logo
456 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
