Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I replaced my 42" V-belt after breaking. Now the mower makes an awful racket when engaged, and the double pulley on the right jumps back and forth. All the pulleys spin freely and the mower works, but i can tell its about to heat up and break again in minutes. What Gives?? Grass is gettin HIGH!!!
  • 130 Answers
Your bearing are bad in the spindale.replace spindale its easyer.
Posted on Jul 22, 2009
Blades wont engage
Hi Mary:
The drive belt will possibly have slipped off a pulley.
With the engine OFF, look between the cutting deck and the underside of the machine. Check the position of the belt as you have a helper move the engage/dis-engage lever back and forth.
Reply as a COMMENT to this post if you need more assistance.
Cheers
Mar 28, 2016 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Install new drive belts and mower still wont move forward or reverse.
Belts dont move mower back and forth, there is a bar that engage the hidrolic transfer, perhaps you move it and you have not tracking power, or, there are a series of rods that actuate the hidrolic, coud be that any of those rods came undone, if any of these to scenarios is happening to you, consider have the hidrolics chec out.
Good luck to you.
Jun 27, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
L115 42'' deck drive belt breaks after only
Possible spindle bearing. ( mandrel bearings )
Spin blades by hand with deck belt disconnected and mower turned off of course. Listen for grinding noise. If so, Replace mandrels and bearings fully. I would replace all few pulleys.
Not too bad price from the right small engine repair shop such as places like Pats Small Engine in Minnesota. ( which pwns)
Jun 13, 2013 | Garden
The brake peddle on my tractor slams back and forth when disengaged
There is a bad spot in the belt or a bad / loose pulley causing this. Its a simple procedure to remove the mower deck. Then you can lay under the tractor and have a good view of the drive components. Lock the brake to slacken the belt Then check all the pulleys. Make sure they turn freely, no excessive play and flat spots. Check the belt for a burn spot. Replace any damaged pulleys and the belt if it has a bad spot and that should solve your problem.
Jul 23, 2012 | Husqvarna Garden
I bought a new belt for my2005 lt 1000 42" deck
for a deck no.. Most everything on the deck is done by springs.. what i would do is look at the deck make sure nothing is rubbing the belt making it rip apart.. or make it to not engage.. i would with the engine off engage the blade and disengage the blade make sure all the brakes are pulling away from the pulleys and making sure all the arms are moving to tighten the belt.. if nothing is moving then i double check the cable or however engages the deck (all mowers are different) and if need the part. If the cable is not broken and is still on deck make sure all springs are lubed. If you have any questions please dont hesitate to ask
Jul 16, 2011 | Craftsman Replacement Belt for 42" Deck
The tractor will not go forward or backward it starts right up but will not engage
1) The drive belt between the engine and transmission has broken or jumped off a pulley.
OR
2) Your hydrostatic transmission is dead.
DO NOT STICK YOUR FINGERS UP INSIDE A RUNNING MOWER TO SEE IF THE DRIVE BELT IS MOVING.
Jul 01, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
One blade cuts and one doesn't. Is this a pulley or a belt problem?drive belt sound hasn't changed. can belts be adjusted or only replaced? what tools are needed?
Set the thing up on some blocks and try to remove the blade which does not turn. Since your belt is working, the pulley must be spinning or there would briefly be an awful racket. If the pulley is spinning but the blade is not then there is something wrong with the mandrel/spindle, or the blade has come loose and has somehow not cut off anyone's foot. Sometimes the pulley and top of the mandrel become rounded out but again there would be some metal on metal noise. Often there is a star shaped protrusion on the bottom of the mandrel which locks into the blade and by virtue of hitting some immovable object, that unstoppable keeper has been destroyed.
Jun 25, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Craftsman 20 HP 42" Mower. I replaced an idler pulley and drive belt on the mower deck. I got the deck reattached to the mower but now the mower blades spin even when not engaged. How can I fix...
Did you obtain the correct replacement belt AND pulley. Double check your part numbers against the parts list for your machine. If you verify that they are correct, double check the belt routing, make sure it didn't get on the wrong side of a belt guide and is in the correct configuration. Look at your idler pulley and make sure the release spring is doing its job pulling it back from the applied position. Make sure that the arm for the pulley moves freely where it is bolted to the deck, it could be bound up with rust or debris. You should have a lot of slack in the belt when it is in the released position. If it does not then either it is the wrong part or improper installation
Sep 17, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Belt has jumped out twice in spite of beltguards
Check and make sure the beltguards are on tight. You want them close to the pulley so the belt will not fall off the pulley, but won't touch the pulley. Also when you engage PTO do it slowly.
Good luck
Aug 31, 2009 | Garden
G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
Aug 07, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
88 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
