Question about Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher
ESD402 HAIER DISHWASHER IS BLINKING OP THE START/RESET LIGHT AND THE NORMAL CYCLE BUTTON IS BLINKING. DISHWASHER WILL NOT RUN. PLEASE HELP
    Brigadier General:
  • 3,513 Answers
Thank You for contacting Fixya.com
There are some common reasons for this type of behavior shown by the dishwasher:
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Best of luck and God Bless.
Please let us know if you have any other queuery.
Posted on Jul 21, 2009
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Control panel shorted
Hi
Thanks for using FixYa. If the control panel has shorted it cannot be reset and it is better to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Haier ESD402 Stainless Steel 24 in Builtin...
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
Haier dishwasher wont run and shows a code OP
Did you every get your this problem solved? I am having the exact same problem
Jun 10, 2009 | Haier ESD400 Stainless Steel 24 in....
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Start light blinking
Test mode is Heated dry - Normal - Heated dry - Normal in 6 sec....
does it blink slowly or three time or fast or 7 times then repeat... let me know and I can help
Jul 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Haier ESD400 Stainless Steel 24 in. Built-in Dishwasher Logo
142 people viewed this question
Top Haier Dishwashers Experts
Tim Doolittle
Tim Doolittle
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Haier Dishwasher Expert? Answer questions, earn points and help others
