Question about Yamaha 12V Air Pump
I have a 2005 Yamaha waverunner. It is hard to start and doesn't want to idle. When I get it going, it only runs at 38 mph. The mechanic wants 750 to rebuild the two carbs. Sounds outrageous, any ideas?
  • palmettocarp Jul 21, 2009
    I was told the carb on the waverunner is hard to get too and therefore labor is high. Is there a less invasive way to clean the carbs such as a gas treatment that I could try
    Sergeant:
  • 160 Answers
I would definitely try a gas treatment and see if it will clear up the problem. As far as an easier way, it's really a pain in the neck to get to. If the carbs need to be re-jetted or worst case injectors replaced there's not much choice. I'm sure however, you can get someone to do it for cheaper than that. That is outrageous! Hope it helps!
Posted on Jul 21, 2009
    Genius:
  • 1,341 Answers
It's not a big job to do and look for someone who can fix motorbike engine and it would be cheaper.The carb is a quite straight forward job but rebuilding does not exist for these,it's either they need to be serviced or changed.One more tip, shop around for the cheapest service man.Hope this helps and forget paying 750 for that.
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
2009 Yamaha vx cruiser waverunner used to do 55mph now won't pass 35 mph
Nevermind those other answers, if its running on all 4the cylinders but just real sluggish and missing top speed then listen up, let's first rule out the possibility of a damaged impeller, now locate your airfilter box and remove the filter, just throw it away because last I checked dirt really doesn't settle on top of water, now locate your throttle body and remove the intake tube from it, now take out the 4 bolts that hold it on and find your flame arrestor element. I've dealt with this problem many times only to find out that the geniuses at Yamaha had installed this screen right after the butterfly which accumulates airfilter material and clogs
Jun 24, 2012 | 2003 Yamaha YZ 250
2001 Yamaha XL700 Waverunner bogs down after running for 30 min
did you replace all diaphrams in carbs and fuel pump ? balanced the carbs ?
Jun 07, 2012 | Yamaha Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
My 2005 Yamaha FX HO Waverunner runs smoothly, but will only go 38 to 40 mph. The RPM Limiter is off, intake is clear, oil level is good and air cleaner is ok. Should I replace the spark plugs?
yes yes yes the new yamahas foul plugs like crazy i dont know if it is a valve defect or what but you will be changing them every year one trick i have been doing to my coustmers watercraft and has been working well insead of ngk cr9eb plugs use a cr8eb it is a hotter plug there for it will burn better and no it will not hurt your ski trust me i have over 15 yrs ex and 6 in r&d research and design
Jun 26, 2009 | Yamaha 12V Air Pump
I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
Jun 12, 2009 | Yamaha 12V Air Pump
2006 yamaha waverunner wont idle
what is it idle at? how much? remove your seat check air filter if is black oily remove it and see if that fixes your problem you may want to change your spark plugs as well # one cylinder may be starting to foul the new yamahas are the worst for fouling plugs use a cr8eb instead of the cr9eb the 8s are hotter and work better try those and let me know thank you
May 15, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
114 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
