Question about LG Refrigerators
My LG refrigerator (LFC23760) gives three beeps every few seconds. Any ideas?
The refrigerator and freezer doors are all closed properly, but the refrigerator lights went out. The temperature control seems to be working just fine but the beeping won't stop no matter what I do. I cleaned out the ice in the back of the freezer and cleaned out the refrigerator to make sure it was not too full. Now I am just stuck. It is working, it just won't stop beeping!
    Master:
  • 507 Answers
It seems like the icebox is picking up a problem with one of its sensors (maybe a door sensor has gone bad so its thinking a door is opened) if however it has a door alarm it can be disabled by the control panel on front of the refrigerator
Posted on Jan 05, 2017
  • Anonymous Jan 06, 2017
    Thanks for the feedback. It was a door sensor but there is no control panel so I couldn't disable it. I ended up figuring out that it was the freezer door sensor. I taped several thin slices of cardboard so that the door switch would be more strongly closed when the freezer door closed. That worked.
  • Denkichu
    Denkichu Jan 06, 2017
    lol well at least if it works
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Subzero refrigerator/freezer, model 590. Door gaskets replaced last year, but it still ices up in top front of freezer? Any ideas?
Ice or frost in the freezer can be caused by one of Three issues:
    • An improperly closed door.
    • Improper ventilation of the freezer.
    • The Ice Maker Flap.
    1. Door Not Closed Properly
    • Make sure that the freezer door closes completely.
    • Make sure that the door gaskets are attached properly to the door and that they are clean. Also, make sure they are sealing properly and are not torn or split.
    Take a dollar bill and close it in the door. If you can pull the dollar out with no resistance, the seals should be replaced.
    • Make sure there are no packages resting against the rear wall of the freezer.
2. Improper Ventilation
    • Space your food out as much as possible to improve ventilation.
    • Make sure that the air vent in the freezer is not blocked.
    Refrigerator Compartment
    If your refrigerator is freezing food, the temperature is set too low. Raise the temperature a few degrees to fix the problem.
    If your refrigerator temperature is too high, condensation may build up and freeze on the bottom of the refrigerator. Lower the temperature a few degrees to fix the problem.
Dec 06, 2016 | Refrigerators
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
My LG refrigerator gives beep continuously, need urgent solution
check if the thread here can help.
Note the Test Mode: LFC23760 / LFC20760 / LBC20514 / LFC20740 / LFC22740 / LRBN20512 Category: Refrigerators -> French Door -> Test Mode LG LFC20740 Refrigerator constantly beeping and fridge not cooling
May 13, 2016 | LG Refrigerators
Since hours I hear 3 short beeps - no open door alarm., No error code.
This model has trouble with ice building up behind the freezer doors preventing them from closing all the way. You may need to defrost.
Nov 05, 2015 | LG 24.7 cu. ft. French-Door Bottom-Freezer...
LG Fridge door constantly beeping when closed
On the display panel press the right key that turns the door alarm on and off
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Refrigerators Logo
2,780 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
