SOURCE: fridge freezer
there is a fan inside freezer behind back panel. if pipework behind panel is covered with ice, it will prevent air circulation and the fridge is affected first
take back panel off and check for ice build-up and that the fan is working
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
SOURCE: fridge section runs warm. Freezer ok it seems.
Sounds like the inside fan is getting worn out. Should vary in speed. Try replacing the fan and see if that fixes it. I'd bet it will. ken
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
SOURCE: Electrolux ER 7626 Fridge not cooling
On these units there is a defrost heater which comes on after about 12/14 hours running time depending on usage.It would cut in for about 15 mins just to get rid of ice accumulated around the Evaporator.This heater or the timer has failed and ice has got between the duct. supplying cold air to the fridge unit.The best thing to do is to defrost unit for 24 hours and then try it and see if you can feel cold air coming up into the fridge.The repair for this is not that successful and you would be better off defrosting unit like a normal fridge/freezer.
Hope this was a help.
Good Afternoon friend, thanks for your post!
From the information you have provided you are receiving a plastic smell inside the back of your Electrolux refrigerator. I can provide some basic troubleshooting steps to help clear out any unwanted odors. You can clean the walls with warm soapy water or warm water with baking soda mixed in. You may also use lemon juice to wipe the interior walls the citric odor can help combat smell. Another thing to use is a pan of kitty litter or a pan of charcoal (not the self-starting kind). I hope this is helpful. -Matt
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
