Microsoft Windows 2000 Professional for PC Logo
Posted on Nov 20, 2007
Windows 2000 i have installed windows 2000 in my system i am not able to goto my computer drives folder it does not show any drives i click and comes back what do i do i also tried to repair but same problem do i have to format it i have installed antivirus in it which has a native boot scan in it and on every resatart it goes to native boot only. no F8 works nor safe mode
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 20, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
624
Points
8
Probably is some incompatibly of the anti virus software, you can try to uninstall the anti-virus software, if you can uninstall it, try to delete the folder where the anti virus is and restart the machine, you can do that using a dos boot disk or any OS that is in a Live CD, like Bart PE, Ubuntu and etc, the easiest way is to use the Win 98 boot disk, but you have to know some DOS commands.
I you can't do that try to format and reinstall it, but use another anti virus i recommend NOD 32 from eset it's light and work's fine.
4answers
I have a WD my book drive. When I try to see the files on the drive they are Not there, But when I click the properties the drive shows half the drive space is used. how do I get the files to show be...
It is due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files. This can be fixed and data would be available to you. However, there are number of steps involved.
It is suggested that go to FOLDER OPTIONS - and select 'SHOW HIDDEN FILES & FOLDERS' and uncheck/ Deselect 'HIDE PROTECTED SYSTEM FILES'.
It would show the hidden files/ folders, if the system not infected Otherwise, from the clean/ virus free system you can see your data and copy all the required files/data. Select the required files and right-click and change the properties of the file by un-checking the hidden attribute. Please note that you can not change the properties (hidden attribute of the files) if the files are marked as system files. To change the attribute of such folders you can download and use iReset.
Also, make sure that you have a good antivirus installed and its updated. Scan your system and clean it.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
2answers
I originally set up the drive with a windows XP 2000. When I plugged it in to my new windows 7, it wouldn't work. It shows the drive is maxed out, and I can't access it. I had used less than one half of...
How many files are on the drive? Are they in folders? The FAT formatting normally used for these drives limits the total number of files unless the files are in folders. I think the value is ~500 items - this is due to the minimum bytes to store each file. (If the files are in folders you can stack 500 items in 500 folders.)
One thing to try is to move the files to your computer, and then return them to the flash drive. (Formatting the drive after the files are safely on your computer is an option.)
Good luck.
Error 1335. The Cabinet file Data1.cab required for this installation is corrupt and cannot be used.
When you try to install Microsoft Office 2000 or Microsoft Office XP, you may receive the following error message: Error 1335-Cannot copy cab file Office1.cab. The file may be corrupt. When you start the computer in Safe Mode and then try to install Office, you may receive the following error message: The Windows Installer Service could not be accessed. This can occur if you are running Windows in Safe mode or if the Windows Installer is not correctly installed. You may receive this error message even when the Office CD-ROM package works correctly on another computer.
When you try to install Office while you are logged on to the computer with administrative rights, you receive the same error messages. uparrow.gifBack to the top CAUSEThis error can be caused by dirty media, CD-ROM read issues, or problems with me... loadTOCNode(1, 'cause'); This error can be caused by dirty media, CD-ROM read issues, or problems with memory allocation. uparrow.gifBack to the top WORKAROUNDTo work around this problem, try the following methods. Method 1: Clean the CD-... loadTOCNode(1, 'workaround'); To work around this problem, try the following methods. uparrow.gifBack to the top Method 1: Clean the CD-ROM loadTOCNode(2, 'workaround'); Use a soft cloth to gently clean the disc. uparrow.gifBack to the top Method 2: Change the memory settings for installation loadTOCNode(2, 'workaround'); To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
uparrow.gifBack to the top Method 3: Install Office by using a flat folder loadTOCNode(2, 'workaround'); To install Office by using a flat folder, follow these steps:
  1. Clean boot your computer. For additional information about how to clean boot Windows XP, click the following article number to view the article in the Microsoft Knowledge Base: 310353 (http://support.microsoft.com/kb/310353/ ) How to perform a clean boot in Windows XP
  2. Save a copy of the Microsoft Office CD-ROM to your computer's hard disk. To do this, follow these steps:
    1. Start Microsoft Windows Explorer. To do this, right-click Start, and then click Explore.
    2. Create a new folder at the root of a hard disk volume, and then name it "Flatfile" (for example, C:\Flatfile).
    3. Locate the drive that contains the Microsoft Office CD-ROM, and then copy all the contents of the Microsoft Office CD-ROM into the C:\Flatfile folder. To do this, follow these steps:
      1. In Windows Explorer, click the CD-ROM icon (or DVD-ROM icon) that contains the Microsoft Office CD-ROM.
      2. On the Edit menu, click Select All.
      3. Paste all the files into the new folder. To do this, drag the selected items on the right side of the Explorer window into the C:\Flatfile folder on the left.
        Note If you receive the "This Folder contains "X" hidden files" error message, follow these steps:
        1. On the Tools menu, click Folder Options.
        2. Click the View tab.
        3. Turn on Show Hidden Files and Folders.
        4. Turn off Hide Protected Operating System Files.
        5. Click Apply, and then click Ok.
        Note If there are errors during the copy process, this can indicate problems with the CD-ROM (media), a dirty CD-ROM drive, or a problem with your hard disk.
  3. Restart your computer the way that you typically do, and then install Microsoft Office from the C:\Flatfile folder onto your hard disk.
uparrow.gifBack to the top Method 4: Install only one Office program loadTOCNode(2, 'workaround'); Install only one Office program, such as Microsoft Access. To do this, select a Custom install, and then cancel the selection for all but one of the Office programs. If the Setup program is completed successfully, restart the Setup program. Restarting the Setup program will take you into Maintenance mode. Click Add/Remove Programs, and then click the programs that you did not install in the first installation of Office. uparrow.gifBack to the top Method 5: Contact Microsoft loadTOCNode(2, 'workaround'); If the previous methods do not resolve the problem, contact Microsoft. For information about how to contact Microsoft, visit the following Microsoft Web site: http://support.microsoft.com (http://support.microsoft.com/) uparrow.gifBack to the top APPLIES TO
  • Microsoft Office XP (Setup), when used with:
    • Microsoft Windows XP Professional
    • Microsoft Windows XP Home Edition
  • Microsoft Office 2000 Premium Edition
  • Microsoft Office 2000 Professional Edition
  • Microsoft Office 2000 Standard Edition
  • Microsoft Office 2000 Small Business Edition
  • Microsoft Office 2000 Developer Edition
  • Microsoft Access 2002 Standard Edition
  • Microsoft Excel 2000 Standard Edition
  • Microsoft FrontPage 2000 Standard Edition
  • Microsoft Outlook 2000 Standard Edition
  • Microsoft PowerPoint 2000 Standard Edition
  • Microsoft Word 2000 Standard Edition
1helpful
4answers
How do you transfer data from this external hard drive to a new internal hard drive that was just installed
Turn your computer on. Plug the external drive. It should show in My computer window. Explore the external drive (by clicking on its icon in My computer). Point and select all you want to copy (CTRL A selects All) CTRL C. ( all that is selected will be marked for copying). Go to folder where you want to copy the files. Open the folder and CTRL V.
Hope it helps
6helpful
Where is the /System32 folder physically located on the drive?
Hi there.
This is the path >>>>>> c:/windows/system32....
So, click on "my computer", you will see "local disk c", click on that, if it says "these folders are hidden" click on "show files". Then click on the "windows" folder, in that folder you will find "system32" folder.
Thanks for choosing FixYa!!
2answers
Office 2000 installation
dear atm99
go to offie 2000 folder and double click the setup file.
Thank you
5helpful
3answers
Problem while starting computer
Hello..
TO remove this error messege follow these steps.
type "regedit" in run dialog box.
Navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon"
There is a string value named "userinit".
The value of this key should "c:\windows\system32\userinint.exe"
Delete anything thing after this.
Now logoff and relogin or Reboot.
Paint on windows xp
Put the winxp cd in the drive. goto start settings control panel, add remove programs, left side add/remove windows components,
if accessories is checked then paint,calc etc are installed.
if acc. is checked goto start search/ files and folders/ all files and folders, type in accessories search c: drive select accessories folder location c:\documents and settings\all usersopen folder and link to paint, calc etc will be there.
Deleting files
You need to connect it to the USB port of a computer. For the Windows operating system (2000 and above) after you connect the jump drive to the USB port, it will show up as a new drive letter in the My Computer folder. Double click this drive letter and the contents of the file will show up and you can delete individual files or the folders by selecting them and hitting the DEL key.
Get back to me if you need more guidance.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
