Question about APC Silcon UPS System
I have several APC Silcon 20KW 208 Vac. some of them were working fine, but the control panel didn't respond. Some day i had to turn off the UPS and when i tried to restart i couldn't because de control panel still without respond. After that, and apc technicians change one board (21446-3)and the problems was fixed. I have 3 board with the same symthom so i'm traying to repair them. (APC new board are around $3000 us). Do you have some experience reparing this boards? what are the major components with fails? Thanks in advance
  • epelaezi Jul 21, 2009
    Thanks. I have a questíon. i don't know what is the name of the board 21446-3. Is Com controller or is the DM controller?
    I'm electronics profesional and i have test equipement but this board doesn't have visual evidence of fail.
  • 5,807 Answers
since it is a UPS it has these stages:
A) a power supply / charger which automatically charges the two batteries and a change-over circuit for output selection
B) Batteries to supply the inverter stage of the UPS
C) Inverter circuits which produces the necessary output if there is AC power interruptions
Troubleshooting the circuit board maybe done by isolating the two circuits
1) the automatic charger
2) the inverter
The automatic charger, Preliminary Testing
these will be done outside the panel
1) locate the main AC input
2) check for output voltages
if there is output , check it with a series ammeter to be precise
3) if OK , then we go the Inverter Circuits
The inverter Circuits compose of a sine-wave circuit oscillator, an astable multivibrator IC.
driver output transistors, output stage transistors or scr and the output transformer.
This inverter circuit only powers-up when there are no ac input signal detected.
The actual trouble shooting of the board requires test equipment for the stages i have mentioned.
the actual fault can be trace and detected by isolating stages.
If there are Schematic Diagrams that you can possibly show me, there will be a high chance of possibility of being repaired.
Another option is the actual picture of the circuit board, at the least we can isolate where or what stage are malfunctioning
if I can see the actual component ,in good pictures ,a possibility of identifying the electronic components and knowing its function for.
a possibility of advising what replacement might be needed for a certain electronic part. or parts
the defective circuit board can be repaired outside the main unit, with a help.
Hope i have helped you, thanks for using Fixya!
Posted on Jul 22, 2009
  • Rommel Cana
    Rommel Cana Jul 25, 2009
    hi,
    the best thing would be divide and conquer
    isolate the stages
    test it manually, with external supply and load
    even go to the extent of testing the electronic parts one by one
  • 11,896 Answers
There are capacitors on these boards that fail. Look for any swelled up capacitors, any burn marks. A capacitor can be tested with capacitor tester or multi-tester. The capactitors control the amount of current flow to each circuit.
Posted on Jul 21, 2009
Problem (Stand by) Silcon 40kw 400v UPS (SL40KHB2)
Your English is OK, I can understand it! I can't say for sure but I believe that some UPS units don't come on unless they batteries are charged and in good condition. Try to locate the cells/batteries and check each one individually with a volt meter. The voltages should be almost the same on all batteries (usually 12 volts).
Apr 04, 2014 | APC Silcon UPS System
UPS SILCON SL30KFB2 ON DISPLAY SAYS "COMMUNICATION TO CONTROLLER LOST", NO COMMAND FROM DISPLAY, ITS IS FROZEN
first check what display and buttons still work?
if there is a problem with the buttons, you have to replace a set of
Oct 04, 2013 | APC Silcon SL30KF (SL30KFB2-TU) UPS System
Silcon DP360, 3-phase 60kva, 400v, year 1993 1. Its old but working perfectly, after I changed the battery bank, because of collapsed cells, it still runs as expected but, I cant get any power readings...
#1. You should call APC Technical Support. It's free, and they will help you. You should get voltage even without a load on the unit.
#2. There is a Tripple-Slot unit for this device. It's specific for the Silcon based units. Read the manual, and there is a PN that you need for it. If it doesn't say SILCON, then it won't work. (I tried).
Paul
Data Centers Canada
www.datacenterscanada.com
Jan 28, 2011 | APC Silcon UPS System
Password Protected for a UPS APC Silcon SL60KF
For Silcon UPS you must ask the person who install the unit if he change the password but for the defualt calibration password is 090909
Aug 07, 2009 | APC Silcon UPS System
APC silcon 40KVA UPS
I understand your problem,
You can chack PSU which instal with controller card.
Your ups will ok after replacment or repairing PSU.
mian_apc@yahoo.com
Regards,
Mar 07, 2008 | APC Silcon UPS System
APC Silcon UPS System Logo
178 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
