Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Engine shuts down
I have a 46" deck Murray lawn mower with a 20 hp Briggs I/C engine. It smokes a lot, and I have to constantly stop to put in oil. It now has stopped completely and I can't get it started. Does this describe ring problems in the engine? What else could be the problem?
  • 130 Answers
Check compresstion.if good check valve if good check beather on engine.but first check
sparkplug.let me know if this help you.ok
Posted on Jul 22, 2009
Toro 22" recycler lawn mower, Briggs & Stratton engine. Engine low on oil, would not start after a few pulls. 20 oz oil added, mower started after a few pulls. Finishing the lawn when a white puff of...
Hi michael, You have most certainly put in too much oil. Try draining a bit off and then clean the spark plug with some paper towel. Leave the mower level for a few hours and then try it again.
Sep 22, 2013 | Toro Garden
42 murray mower deck TROUBLESHOOTINGmanual
It sound like pto or safety switch may be shorted. Hope this helps.
Jul 31, 2013 | Garden
Engine cranks but does not start on 21 hp briggs and straton
May have oil in the carb. If it smoked its burning oil due to having to much in it.
Jul 02, 2013 | Husqvarna YTH21K46 (46") 21HP Lawn Tractor...
I stored my Briggs and Stratton Murray 4.5 Lawnmower at an angle and oil came out the exhaust.
Just let the mower sit on the level for a while. Then be sure to check the oil level before starting the engine. It'll probably blow some oil smoke, but then it should clear up and be fine. You should only tip your mower in one direction, ever. That is down on the handlebars; up on the front. This way, the fluids have no where to run. Also be sure the gas tank is not full or fuel will run out the vent in the cap.
Oct 09, 2011 | Briggs & Stratton Briggs Stratton...
Need manual for Murray 20" cut 3.5 hp Classic push
This engine is one of Briggs & Stratton`s basic engines, quite a simple engine, post your problem and i`ll answer,
If you really feel that you need a manual they are available through some outlets, try Wal Mart. or ebay
Jul 03, 2011 | Briggs & Stratton Garden
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
17 HP Briggs & Str lawn mower engine that is smoking a lot -
compression test it can either rent or buy one should be over 90psi!!!
Jun 28, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
186 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
