Question about HP Compaq nx6310 Notebook
Both of the usb ports on my son's compaq nx6310 are not working, are these on the mainboard, or is it a small board. Tony
  • 4 Answers
They are most likely a part of the motherboard. If they don't work, you can try reloading the chipset drivers for the motherboard which should come with the drivers for the USB ports.
Posted on Jul 21, 2009
Compaq NX6310. Wont power up. When I press silver ON button the orange LED on front flashes 7 times ...And nothing more. I am measuring 19volts on power adaptor on the inside and outside surfaces of the...
check for damaged usb ports, this can often cause this problem. if you find distorted contacts within the usb port, try to straighten them or isolate them. hope this helps.
Apr 27, 2011 | HP Compaq nx6310 Notebook
My usb ports on my compaq persario co61 dont work anymore the ports dont get power aswell wat should i do
Please try these steps:
- go to the device manager - see USB ports section and right click on it - select uninstall and restart the computer
Windows should be able to reload the USB drivers and correct the issues possible caused by data corruption. If still the same, the USB ports might be having troubles not being detected in the system and there might need servicing from the manufacter or possible motherboard replacement since it was integrated with the mainboard.
Apr 10, 2011 | HP Compaq Presario V2000 Notebook
A small black cao of the usb port drop out, what
Well, unfortunately, this is usually, fixed INSIDE the USB port. If it has broken off, then really the ONLY way is to replace the entire USB port Socket. I have fixed them before, by using a tiny amount of "Super Glue" and mating the two surfaces back together and it has worked, sometimes it will not work, it is very fiddly, but can be done. be careful not to get glue onto the contacts. I usually use a magnifying glass and fine tweezers.
Apr 19, 2010 | HP Compaq nx6310 Notebook
Compaq evo laptop, getting to and replacing the USB ports.
Hi
In almost all cases (90%) I have seen, the USB ports are not replaceable or repairable since they are soldered to the main board.
Additionally, the manufacturers generally do not sell these components seperately and only as part of the main board.
Before going through the effort of getting to the ports I would contact the manufacturer (HP) and see if you are able to obtain the (USB) part to fix.
you may be faced with having to replace the mainboard which will require quite a bit of labour and removal of items including a high cost that you may opt not to choose?
If you need more help in deciding on what option to choose let me know
Feb 15, 2010 | HP Compaq Evo n610c Notebook
My compaq Nx6310 notebook pc can not detect the USB ports when using windows XP
loadTOCNode(2, 'resolution'); To fix this problem on a Windows XP-based computer, you must be running Service Pack 1 (SP1) or later. To determine if you have Windows XP SP1 or later, click Start, click Run, type winver, and then click OK. If SP1 or later is not listed in the About Windows dialog box, then use Windows Update (http://windowsupdate.microsoft.com) to install the latest service pack before you try to fix this problem.
this will be the link : http://support.microsoft.com/kb/314634
ERNZ
Feb 09, 2010 | HP Compaq nx6310 Notebook
My usb ports for HP Compaq nx6310 laptop do not work
Probably you have not installed the correct driver for the USB port. Check whether you have any yellow "?" marks in the "device manager" window. To check that simply right click the "my computer" and select "properties", open the "hardware" tab and click the "device manager" button.
Apr 13, 2009 | HP Compaq nx6310 Notebook
Need to reset my cmos settings on my compaq presario desktop
Just refer to your mainboard manual. If you don't have, the CMOs clear key is usually near the mainboard's battery. Besides, mainboards usually indicate in small print the different ports. You will need a magnifying lens to see them.
Aug 28, 2008 | Compaq Computers & Internet
My omnibook 500 bios password is loss how is open
here are the instructions
-Remove the hard drive.
-Remove the keyboard.
-Disconnect the reserve battery cable from the system board connector.
-Pry the reserve battery free from the system board. The reserve battery is attached to the system board with a piece of adhesive tape.
-Remove any remnants of the adhesive tape from the EMI shield.
Step 2
Make sure all power is off/disconnected and batteries removed before attempting anything like changing parts
in HP > Compaq nx6310 is in a easy to get-to location, but changing it is a pain. Remove your main battery, you'll see a small square of silver plastic in the middle of the compartment. The CMOS battery is underneath of this square.
The battery's connector is on the mainboard, just below the area of the "ALT" key. Unfortunatly, you have to dissasemble the laptop to change it.
Rate me as fixya if u got help?
Aug 22, 2007 | HP OmniBook500 250MB Zip Drive Module...
HP Compaq nx6310 Notebook Logo
156 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
