Question about Zanussi FS1455W Front Load Washer
My washer wont spin
My zanussi washer when i put it on a cycle it will fill up with water you can hear the motor working to make it go round but the drum doesnt move ive checked the belt its ok dont know what else to do can you please help
  • Anonymous Aug 14, 2008
    my washer goes threw the cycle but the drum does not work its a hotpoint aquarius
  • 139 Answers
On the motor there are what you call carbon brushes.. these wear out over time, this then the motor stop spining check and get back to me . cheers doc
Posted on Nov 28, 2007
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
Zanussi fx 1465 w program fills with water then will not spin any ideas
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Feb 22, 2011 | Zanussi ZWF10070W Front Load Washer
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
My Zanussi FLA1001W will wash but will not sin or
Check the impeller on the pump free to move. if ok check electrical connections. if ok either pump is faulty or it could be main pcb (or both)
Oct 17, 2009 | Zanussi FLA1001W Front Load Washer
Drum wont turn on the spin cycle, it's ok on a
if its pumped all water out and wont spin sound like your motor brushes are worn.
Oct 16, 2009 | Zanussi ZWF1230W Front Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi wdj 1094 washer dryer
possibly the motor brushes are worn, the clicking is the pcb relay changing the motor direction.
May 19, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FS1455W Front Load Washer Logo
282 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
