Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printer says out of paper when the tray is loaded
The printer keeps saying 'out of paper' when it is full. Have tried switching off the printer and starting again, bvut does not respond.
I have the same problem, however if I sit here and push the ok button, it prints the next two pages and reports that it is out of paper (even though it isn't). So just keep hitting 'ok'.
I suspect - and I haven't completely tested this yet, that there is something up with the application that is calling the print dialogue. Also it seems to be a consistent problem when I choose 2 sided print. Note that when I hit 'ok' it isn't printing 2 sided even though I set that option to true.
Posted on Dec 04, 2009
    Problem Solver:
  • 9 Answers
1. Shut the printer down
2. disconnect the power cable and network cable if you have one
3. wait 5 minutes
4. put the cords back in
5. power the printer back up
Good Luck !!!!!
Posted on Jul 21, 2009
Keeps saying load paper, paper is in
Are the rollers worn out? If they have a slick appearance, that is your problem. Also examine the tray and see if it is lifting properly.
Sep 30, 2017 | HP Photosmart 3310 All-In-One InkJet...
Xerox Phaser 6180 keeps saying load papertray with
Remove the paper tray and check the guides. Make sure they are lined up on the 8.5 X 11 marks. If it is lined up, try going into the menu of the printer and reset back to defaults.
Jul 21, 2011 | Xerox Phaser 6180N Laser Printer
My printer wont print keeps saying load paper but tray is full. i have checked for broken bits and stray paper but all seems okay.
there is a small lever that lifts up when paper is inserted; this closes a switch; look for it in the paper try compartment.
Jul 11, 2011 | Canon LaserShot LBP5050N A4 Colour Laser ,...
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Mp780 - Paper attempts to feed and fails Message: Load paper
Your paper feed source is wrong .Go to the printers control panel and change the feed source.
If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Printer thinks it's out of paper
Have you tried pressing the start button after you loaded the paper?
Also, try restarting the printer while keeping the paper in there.
Jan 09, 2009 | Office Equipment & Supplies
Easyshare 500 printer
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Dec 11, 2008 | Kodak EasyShare Photo Printer 500
Printer won't accept paper in tray
try to load about 20 sheets of paper.try perform reset..unplug the power cable at the back of the printer then press and hold the # and 3,insert the power cable and if you could see that the printer is starting to boot-up you can now go ahead and release the buttons.but if the issue is still occuring the printer paper sensor is defecte=ive and needs to be serviced/replaced......,,
Aug 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printer will not catch paper in tray
The rollers need to be clean or replaced.
Feb 04, 2008 | Dell M5200n Laser Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
553 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
