Question about Sony Ericsson K800i Cellular Phone
Please help meeeee
I was copying my chip contacts to my phone.i switched it off whiles it was copying.since then i get a red light flasing or blinking at the infrared port each time i try to switch it on
  • 32 Answers
Re: please help meeeee
Flash the phone. I had this problem not that long a go and used wotan server. All now works fine. READ the wotanserver manual before trying to flash your phone as if you do things incorrectly you may kill your phone completely.
Posted on Feb 02, 2008
0 characters
3 Points
Phone doesent turn on flashing red light when you push the power button. please help.
Try this , it helped me. 1. plugin the charger (or data cable) for about 15 minutes and keep the red light blinking. 2. while the charger (or cable) is hooked to the phone, remove the battery and memory card for 10 to 12 seconds. 3. keep the memory card out and put the battery back in and whalah, it startes up. (really hope this helps)
Nov 14, 2010 | Sony Ericsson XPERIA X10 Cell Phone
Sony Ericsson K610i does not working...while am trying to switch on...the red light blinking
the battery might already be empty. try charging it for 10 minutes or longer before switching it on.
Oct 06, 2009 | Sony Ericsson K610i Cellular Phone
Sony Ericsson K810i not starting.Infrared blinking
then the problem is of software . please contact ur dealer
Sep 12, 2009 | Sony Cell Phones
Red light flash slowly but bright and nothing more, can't turn it on, won't light up. What must I do?
Jul 25, 2009 | RIM Blackberry 8110 Cellular Phone
Sony ericsson w580i wont turn on light on side blinks red
Please visit the Sony Ericson technical shop, donot try to open because once the seal breaks, warranty gets over
Jun 16, 2009 | Sony Ericsson W890i Cellular Phone
Flash is not working
You have to change the sitting to night mode and turn on the linght. If the linght turn on then please have a look to your mobile sincer may some dust cover it.
Nov 22, 2008 | LG Prada KE850 Cellular Phone
Sony Ericsson W850I
Most new phones allow charging with the USB cable. With some phones, you also have the option to select whether you want to allow USB charging. If you're trying to charge with USB, make sure that your phone supports USB charging and that the option is switched on.All the best!
Happy to help
Have a nice day!
Jun 05, 2008 | Sony Ericsson W850i Cellular Phone
Blank and blinking
the firmware need to be reflash on the phone so take the phone toa mobile service center and have them flash it for you or you can do this online at
Oct 31, 2007 | Sony Ericsson K610i Cellular Phone
Motorola mobile model 925552xzbsa
please check for water damage clean with IP solution & connect the charger to phone with out battery check the voltage from battery connecter voltage must be 2.75, if yes need to flase the phone
Sep 05, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Sony Ericsson K800i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
