Question about Sony Xplod XM-1652Z Car Audio Amplifier
How to install Sony Xplod XM-1652Z Car Audio Amplifier
I have a Sony Xplod XM-1652Z Car Audio Amplifier that i need to hook up to 2 subs. What cords do i need, and how do i do it?
  • 15,935 Answers
First you will need to post the # of voicecoils each subwoofer has, and their resistance.
Next - you can purchase an amplifier installation kit just about anywhere that will supply you with everything needed to wire up 1 amplifier.
Power wire w/fuse
Ground Wire
Remote Wire
RCA cables
Speaker Wire.
CLICK HERE for your manual.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 24, 2009
I have a sony xplod 1652z 1000 watt amp and want to hook up 2 subs and the speakers that are already installed in the truck is that possible?
thats not a good idea because you are running too many speakers off that amp it it could possibly blow a channel or the whole amp. trust me i've done it
Jun 10, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
Getting my son a sony xplod xm-1652 2 channel what subs would sound good and the things says 1000x2 and 500x2 what is the truth
165 watts x 2 @ 4ohms and 200-230 watts@ 2 ohms or 400-460 watts bridged into a 4 ohm mono load is what the amp will actually do. A single 12 inch sub or a pair of 10 inch subs or 12s would be great
Nov 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod
If your still getting a green light, it at least sounds like the amplifier portion may still be funcitonal. Perhaps your inputs are blown. If your comfortable with electronics, pop the cover, and try patching a signal directly to the amplifier stage. and of course check your source.
Jun 20, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a SONY XPLOD XM1652Z 2 CH 1000 watts hold two 12in subs?
should do easily though you may need to employ the use of a cross over just incase something goes pop and burns you're car out when you park it after you've been hammering the subs.
May 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Will a sony xm-1652z 1000w amp run 2 dvc 4 ohm 800 watt rms subs?and whats yhe best wiring option if so?thx
IT WILL POWER THE SUBS WITH NO PROBLEM. I WILL NEED TO KNOW WHAT THAT MAX WATT THE SPEAKERS CAN HANDLE BEFORE GIVING PROPER ADVISE. RMS IS RECOMMENDED MINIMUM SETTINGS.
Feb 21, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony XM-1652Z
What head unit do you have?
Is there a dedicated subwoofer output?
If not, have you switched the rear output to sub output?
Is the amplifier set to LPF (low pass filter), and the gain turned up?
Many things can be wrong, but the fact that there is anything coming out of the subs is a good thing.
Start at the beginning - Head unit, then check amplifier gain/crossover setting.
If you are using a hi level adapter on factory radio, is the Bass on the radio up? is the output gain on the convertor up?
Jan 13, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
How to measure watts
You need a Volt Meter and an Ohm Meter. P = VI & I = V/r, so Power = (Volt^2)/Ohms .
You can get the ohms by hooking them up to the subwoofer input wires, and you get the volts by hooking up to the amp output terminals/wires. Although, amps will put out different voltages for different frequences, this should give you ballpark estimates.
Nov 10, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier cuts out when turned up loud
The best thing to do is to get a amp that is more watts than your subs, not the other way around, speakers are known to handel a lil more power but amps cant produce more power than they are capable of... your ground wire should be thick also, say 6 to 8 mm or so, and its best to put in a cap and an equalizer.
Cheers
Dec 19, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod XM-1652Z Car Audio Amplifier Logo
3,655 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
