Question about Toro Lawn Mower With Toro Power Tools
HOW DO I TELL IF ITIS SOLENOID OR STRATER BAD ON MY SEAR LAWN TRACTOR?
If when you try to start you can hear a click in the starter solenoid and the jump start as explained starts the engine then the problem is usually the starter solenoid
Posted on Aug 05, 2009
  • 202 Answers
You can check the starter by removing it and using jump cables to the body- and starter terminal to +. still there are the saftey switches in the picture when on the tractor. if you have a bad switch then it also wont start.
Posted on Jul 21, 2009
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
My lawn tractor won't start/turn over. Battery is good
There should be a fuse in the circuit to check. The interlock system can be difficult but you will usually have a switch for the seat, PTO lever, neutral, and clutch. Check for loose plugs or wires.
Feb 14, 2015 | Sears Garden
Doesn't start. solenoid clicks
1. ( bad solenoid)
2. bad cable from solenoid to starter
3. connections are loose
4. bad starter
Oct 27, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sear ltv 10 varidrive lawn tractor
OLDER SEARS TRACTOR WILL NOT SHUT OFF WITH KEY. STARTS FINE.. ANY IDEAS WHAT TO LOOK FOR?
Jul 23, 2010 | Sears Garden
Won't start,the battery needle goes (-) when the key is turn to start
Can you hear the Solenoid click when to try to start? If not, I had the same problem it was the Solenoid. Sears insisted it must be the battery even though it was weak but not dead. Replaced the battery but it still would not work. Replaced the Solenoid and did the trick.
May 03, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a sears LT 2000 THAT WILL NOT START. IT IS
Take starter to local parts store and have it checked.. First thing try jumping posts on solenoid to see if it starts.. If it does then solenoid is bad.
Jul 04, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Replacing starter
The gear / part on the starter is commonly called a "bendix" gear, and it rotates into position only when the starter switch is engaged in the "start" position. As soon as you release the switch to the "run" position, the starter' bendix gear drops down so that the engine's flywheel can spin without causing the starter to turn as well. Just re-bolt the unit back to the engine, and reconnect your battery cable.
Apr 11, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Toro Lawn Mower With Toro Power Tools Logo
901 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
