Question about Kodak EasyShare V603 Digital Camera
My camera will not hold a charge. After taking a
My camera will not hold a charge. After taking a picture using the zoom it retracks and turns the camera off. The 3 green lights indicate the charge is ready. After taking a picture the red flashinf battery light comes on. I put a ne battery in the camera a month ago.
    President:
  • 2,761 Answers
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
The zoom lens don't retrack Display don't
Charlene, It seems that there some dust that has entered between the lens housing and the camera body. To remove it you must use the vacuum cleaner to pull out the dust from this place. And keep switching on and off the camera so that it tries to move the lens inwards/outwards. If this does not work then the movement mechanism of the lens may have got stuck and would require more serious efforts for which you may or may not have to tools and knowledge.
Nov 02, 2009 | Vivitar ViviCam 8400 Digital Camera
Canon PowerShot G2 buttons don't work
You have a bad button board . This is a single board with a series of small button switches that control all these functions. Most repair shop will charge around 75.00 to fix.
Jul 01, 2009 | Canon PowerShot G2 Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
Zoom Error
try to manually adjust the zoom. My camera is doing the same thing. sometimes I can get it to focus after forcing the camera to zoom in and out a few times. No one well let me know how to get hold of a repair manual to adjust this, but when I figure it out I will post it.
Dec 14, 2007 | Fuji FinePix A345 Digital Camera
FX8 all button frozen
I am not sure if this is a solution. but one time, i turned on my camera when the battery is really drained. usually (when it was broken) it will automatically zoom in. but that certain period when i turned it on, even before it can zoom in, the battery drained and the camera went off. i charged the battery and when i put it back and turned on the camera, it works fine. it is still working fine. good thing i didnt had the repair center fix it, because they charge really high price.
Nov 11, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Blurry pictures with Pentax K1000
It may be the equipment or it may be the way you are holding / taking the picture.
Here are suggestions on how to take better zoom lens pictures (this also applies to any camera) before you start diving into the equipment.
1) Use the fastest shutter speed possible. This reduces the amount of time of exposure, this limiting the amount of motion blur that can happen.
2) Don't hold the camera by hand. Either use a tri-pod or rest the camera on something stable, like a wall, rock, bench, etc. This makes it less likely that the camera will move when you are taking the picture, thus reducing motion blurr in the image.
3) If you have to hold the camera by hand, hold the zoom lens with your left hand (because it is more towards the center of gravity than the camera is) & try to slow your breathing & take the picture between heart beats.
4) Also, another thing that helps is to use a remote shutter release (such as that rubber bulb or plunger attached to the shutter release). I would also say using the self-timer would help, but the K1000 doesn't have that. This is so the camera doesn't shake from you pushing the shutter release button.
5) Make sure the lens is clean! Even get one of those lens pens from your local camera shop.
If you have tried all (or most of these) then its time to start looking at your equipment, such as . . . is your shutter getting stuck when exposing, thus lengthening the exposure and making for a blurring shot or do you need glasses? <grin -- which is why I find it really difficult to use manual focus equipement now, because my eye sight is really bad!>
Take care & Happy Imaging!
Glen
Sep 06, 2007 | Pentax K100D Super Digital SLR Camera
Zoom lens stuck
Evidently the mechanism is damaged by a knock or dirt has entered the system. There is no self repair remedy Contact the HP customer support site for further advice
Jul 28, 2007 | HP Photosmart 735 Digital Camera
Kodak EasyShare V603 Digital Camera Logo
144 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
