Question about Motorola Mobility Motopure H12 Bluetooth Headset
Motorola H12 headset won't take a charge. Just flashes red when charging, flashes blue when turned on but doesn't work. Worked fine one day, put it on the charger, hasn't worked again.
SOURCE: Not sure if Jabra bluetooth headset or charger that not working
I had the same problem, called support, they told me battery is defective or too old and doesn't accept the charge. Battery in a headset is hardwired and can't be replaced, so the whole thing is trash :(
Posted on Jul 10, 2007
Cpyles07
  • 56 Answers
SOURCE: Motorola H700 wont sync with my Palm Treo phone?
Did the headset become unpaired with he phone? If so make sure the boom is closed and Hold down the button on the side until it starts to blink then run the wizard
Posted on Dec 06, 2007
SOURCE: Plantronics Bluetooth Headset P590
my headset doest charge too. i tried the desktop stand...and the AC adaptor....but no power comming through. i cant say that my power isnt working coz when i tried the universal adaptor...that was charging fine. i have got a P590. PLZ HELP.....thankxxxxxxx
Posted on Jun 17, 2008
  • 46 Answers
SOURCE: HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
SOURCE: Motorola Bluetooth Headset MOTOPURE H12
My H12 manual has the passcode as 4 zero's for most phones.
Posted on Mar 21, 2009
My Motorola HK250 wont charge is flashing red all the time
Mine is too. Mine will sit solid red for a little then turn solid blue. Then after that it will flash red all the time. I've had it on the charger for the last 2 days and that's all its been doing. I read the flashing red light means the battery is either unchangeable or not making proper contact.
Oct 22, 2013 | Motorola Mobility HK250 Universal...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
Plantronics Pulsar 590A headset won't charge anymore.
I too have the same problem as jessehaye154, does anybody know of a solution?
Apr 10, 2009 | Plantronics Pulsar 590A Wireless Headset
H12 bluetooth will not charge
As the headset is repeatedly charged, the pins on the charger starts to not reach the blue tooth ear piece to charge. I clean the dust around the edges on the contact area and was able to get it to charge
Feb 09, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Feb 05, 2009 | Motorola Mobility Motopure H12 Bluetooth...
Motopure H12 will not pair.
have you tried charging ur h12 headset until its full? if so then the internal battery inside the headset is probably getting old or dying out, suggest you bring it to ur nearest local Motorola store for details on repairing the headset.
Feb 03, 2009 | Motorola Mobility Motopure H12 Bluetooth...
My H12 worked great till a few days ago and now I cant hardly hear anyone on the other end.
we will try toss, when your in conversation with a patient person try your phone blue tooth volume and once it says full volume try hitting set. good luck.
Jan 02, 2009 | Motorola Mobility Motopure H12 Bluetooth...
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Motopure H12 Bluetooth Headset Logo
325 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
