Question about Kenmore 73952 Gas Dryer
No Heat Model # 970-C85192-00;Not getting heat!
  • 6,784 Answers
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Jul 21, 2009
Oven does not heat up, broil also not working Kenmore electric range model 970-6786, would that be a problem with the elements?
chq your fuses make sure both are good if breakers switch off then on again to make sure one hasnt tripped
Dec 17, 2016 | Kenmore Kitchen Ranges
Model 970-5574. Why won't the elements heat?
really sounds like you need a repairman and an electrician at the same time .
Jul 17, 2015 | Kenmore Kitchen Ranges
Are there fuses for the oven on my flat top stove oven. it is very slow to heat up
Yes, there are fuses (or at least 1 fuse), but if they were bad, your oven wouldn't heat up at all. You may have a bad element. Does your oven have a visible (or hidden) bake element? Does it have a convection fan & element? One of those may be bad, causing slow heating.
Oct 07, 2014 | Kenmore Kitchen Ranges
Kenmore dryer model 970-C85092-00 no heat
element or stats........cheers
Apr 15, 2014 | Dryers
On my kenmore dryer 970-c82062-00 I can get all 3 timers to start but the heated automatic dry portion does not time out.
that model number doesn't come up,you sure that isn't the serial number?also does the dryer have heat,when you run it on time dry the timer just counts down like a clock,when on auto or more or less the heat comes on until the dryer heats to temp. the heat shuts off and the timer will advance,when the heat comes back on the timer stops moving,it will do this until the clothes are dry,if you do have heat you could have a bad sensor or a bad cycling thermostat but you'll have to check it with a meter.send the model number and i can help you better.
Feb 16, 2014 | Dryers
No heat in dryer model no. 970-C84102-00
Is this the Maytag gas dryer?
Oct 22, 2012 | Dryers
I have a Kenmore Dryer (Model 970-C87022-00), there is heat, however it does not dry the clothes. They actually feel wetter.
The most typical reason a dryer will heat yet not dry the clothes is going a blocked.restricted or crushed vent. Check the venting from the back of the dryer all the way outside and make sure its blowing good air pressure all the way through it,Also check inside of the dryer at the housing where the blower wheel is for lint build up.
GENE
Sep 18, 2011 | Dryers
I have kenmore washer/dryer combo model 970-C98802-00. Been using for years until last week it starts tripping the breaker when using the dryer. It does not trip the breaker if no heat. It only trips the...
since it runs on air you have a grounded heater coil. Either the heater has sagged or broken and is touching the frame, here is a website that will assist you, Tim:
http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
May 31, 2011 | Dryers
DRYER RUNS BUT NO HEAT.WHERE CAN THE FUSES BE ?MODEL NO 970-17802-20.SERIAL NO XE73210031.KENMORE
If it runs but no heat that is probably your heating element.
I recently worked on one of theses and got my grandson to snap a few photos of the repair.
417.91702000 Broken dryer belt and felt replacement
Jan 30, 2011 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 73952 Gas Dryer Logo
554 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
