I HAVE A DYNEX DX-LCD19-09 REPLACED MAIN BOURD NOW PICTURE IS SHIFTED TO THE RIGHT. i need to get in the service menu to change hoz. center.
  • Dale Hunter Jul 25, 2009
    thank you very much
  • 19,396 Answers
I do not know if the procedure below will work on your model. It is the procedure to access service menu on a Dynex LCD TV LC32HV40:
3.1 Method for using factory menu:
a) Press “INPUT”, “2”, “5”, ”8” and “0” in turn to enter level-one factory menu;
b) Press “CH+” and “CH-” to move the cursor to the adjustment page of the level-one factory menu
then press “OK” to enter;
c) Press “CH+” and “CH-” to move the cursor up and down;
d) When the cursor move to a certain adjust item, press “ VOL+” and “VOL –“ to adjust value;
e) Press “MENU” to exit to the level-one factory menu;
f) Press “EXIT” to exit the factory menu.
g) After exit the factory menu, press “SLEEP” to enter the factory menu again as long as power on.
h) “Power on mode” item of “Otherseting” menu: on= turn on; off =standby; memory=memory
function of turn on
Posted on Jul 21, 2009
I have a dynex DX-40L261A12. The colors are out of focus .its in the menu, playstation and cable
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 27, 2017 | Dynex Televison & Video
I have a Dynex DX-55L150A11 and it scrolls through the inputs non stop can mine be fixed possibly no main boards availanle
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Aug 06, 2016 | Dynex Televison & Video
Try to turn power on ...hear it make a sound, red light turns blue like its turning on but shuts right back off in an instant...fixable or not?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 26, 2015 | Dynex DX-LCD19-09 19 in. LCD TV
Dynex™ - 40" Class / 1080p / 60Hz / LCD HDTV Model: DX-L40-10A Has no sound and no picture. The blue lights turn on but that is it.
Jul 09, 2015 | Televison & Video
How do I test the main board?
Please contact the authorized service center for Dynex. Gopakumar Gopalan Google
Mar 02, 2014 | Dynex 756TXBCBZK05700 Main Board for...
Replaced the T-CON board on a dynex dx lcd32-09 no issue resolved
Check all ribbon connections, and LVDS (cable from main board to t-con) connections. I'm thinking you may have an issue with the LCD panel itself. If that is the case, it will not be worth repairing.
May 12, 2012 | Dynex DX-LCD32-09 LCD TV
Finally bought anRCA antenna for my new Dynex TV.Nothing no signal,no way to scan for channels I can see.AGGH.Is it a lemon?
Which Dynex TV do you have? The manuals for most Dynex TVs are available from the product page. Start at http://www.dynexproducts.com/products/televisions.html . If you have an older Dynex that isn't on the main list, check under Discontinued Products. Alternatively search for your model. Then click on the Support tab to find the manual for that model.
For at least one Dynex TV (DX-32L152A11), the procedure to scan for channels is below.
To scan for channels, first make sure that the current input is set to TV. (Press the input button on the TV or the remote). Then press Menu and use the left/right arrows to select TV. Then press Enter or down arrow (the manual says the right arrow). Use the up/down arrows to select the entry to change. First, make sure that the Tuner Mode (first item) is set to Air (use the left/right arrows to change this). Press Menu to go back to the TV menu. Then go down to Channel Scan and press Enter. You may need to confirm the channel scan and press Enter again. Wait for the scan to be completed.
On a discontinued model (DX-32L151A11), the procedure is slightly different. With the input set to TV, press Menu. Select the Channel submenu and press Enter or down arrow. Set the TV mode to Antenna (use the left/right arrows to change the value). Then press the up/down arrows to reach AutoScan. Press Enter. Move cursor to highlight Yes and press Enter again. Wait for the scan to be completed.
I hope this helps.
(There were some Dynex monitors built. They usually do not have a coaxial antenna in port since they didn't have tuners.)
Jul 29, 2011 | Olevia LT32HVE 32 in. LCD Television
Dynex 24" lcd led tv
Check to see if mute is on, and through the menu to see is sap is on. Sometimes button are accidentaly pressed. If none of the above, the ntry replaceing your main board.
May 05, 2011 | Dynex DX-LCD37 TV
I have the dynex dx-lcd32-09 model tv.One day I was watching ashow on tv and all of a sudden the picture went white,But can still see the image.I tried everything from turning it on and off to back on...
The T-con also called LCD contoller board needs to be replaced. You can check this link to find the part for your LCD. This board is located in the upper middle part on the screen under a metal shield.
I would suggest to contact them first before order the T-con board.
Sep 14, 2010 | Dynex DX-LCD32-09 LCD TV
I got a dx-lcd32-09 and just the screen went of
SIMPLE BUT HARD SOLUTION, TO CORRECT THIS PROBLEM YOU WOULD NEED TO REPLACE THE MAIN BOARD. SIMPLE. I DONT KNOW WHO ACTUALLY CARRY PARTS FOR THESE BECAUSE ITS A BEST BUY BRAND, HARD PART.
MAIN BOARD IS A SURE FIX IF YOU CN FIND IT
Apr 27, 2010 | Dynex DX-LCD32-09 LCD TV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
