Question about Toshiba e-Studio 205 Copier
My scan feature became disconnected during a power outage.
The folder which I have previously been able to scan documents into is still on my desktop, however now when I scan an item on the copier (it appears to work, on that end) and then go to open the folder on my desktop to view the document, I get a message that "The drive or network connection that the shortcut 'Toshiba Scans.lnk' refers to is unavailable. Make sure that the disk is properly inserted or the network resource is available, and then try again." Please help!
  • 11,896 Answers
Make sure ToshibaScans.Ink is not set as read or write only file.
Go to the file, right click,properties, check to make sure boxes are not marked, then hit apply.
Posted on Jul 21, 2009
How do I scan a document in pdf format ?
The process is changed during SAVE AS function. You can set to save into a folder, and in which format (.jpg, .pdf, etc.).Use the desktop application, tons easier than the printer interface.
May 19, 2016 | HP LaserJet 2430 Printer
How do you save an email destination when scanning on ricoh aficio mp 7000
Not quite sure what you mean .?
Make a Template From a Scanned Item
During the course of running a business or operating a home office, you might come across a hard-copy document that you wish to copy and customize to use in the future.
This can be accomplished in a matter of minutes, whether it's a professional looking invoice, fax cover sheet, or any other type of document.
There is no real technical expertise required to convert the scanned item into a reusable document.
Place the item you wish to convert in your scanner or all-in-one peripheral device.
Open the device's software interface by clicking its desktop icon.
Select "Scan" and then scan and save it as a ".doc" file or word processing file.
Open the scanned item using a word processing suite, such as Microsoft Word or Open Office. Review the scanned item to ensure all characters were properly rendered during the scan.
Save the file as an easy to remember name in the folder of your choosing.
Then press "Ctrl" and "A" simultaneously, followed by "Ctrl" and "S."
Open a new word document by going to "File" and "New."
In the new document, press "Ctrl" and "V."
This creates a workable, editable document while preserving the original.
Save the new document with a similar, easy to remember name.
Customize the content of the new document to your liking, inserting your particular information. For instance, if it is an invoice you've scanned and wish to emulate, then replace the other business' name and contact information with your own.
Save the document periodically to avoid losing information.
Copy an Email Folder to a Hard Drive
An email file is a file that comes in your email with important information or pictures in it.
When you get information in your email account, you might decide to transfer the information to your hard drive.
This is a process that is easy to do, and it is a good idea to do it, because scam artists or hackers can get into your email account and ruin or delete information.
You can also save an entire email folder, such as your Inbox or Sent folder, by saving or exporting it.
Saving an email folder to your hard drive is extremely easy.
Open your inbox and click on the message that contains the email folder.
Right-click on it and choose "Save As."
Choose a location on the hard drive of your computer and click "OK" to save the file in that location.
Choose a name for the folder so you'll remember what it is.
Choose "Save" to save the email folder.
Click on the headings for your email folders where messages are stored, such as your Inbox, your Sent folder and your personally named folders.
Right-click or double-click on the heading until you see a "Save Folder" option. Depending on your email program, you might be able to click "Save As" and save the folder as a document onto your computer.
If you do not have a "Save As" option, look in your "Tools," "Menu," "File Menu" or "Options" menu.
Choose "Export" and specify the particular folder you would like to save.
As "Export Destination," choose the place where you'd like the folder saved on your computer.
When you click "Export," it will be saved.
Oct 01, 2013 | Xerox Office Equipment & Supplies
Problem scanning and saving pdf docs to desktop
I have the same problem. Try this:
If you set network path similar to: \\Server\Share you will receive an error. Try set path to folder located in network path eg: \\Server\Share\Folder
It works for me
Aug 29, 2012 | Office Equipment & Supplies
How to send scanned documents abroad
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
Best of Luck!
Sep 06, 2011 | Computers & Internet
How do I set up the scanner on my HP J3680?
use the CD that came with the printer.it has the full feature software that will enable the printing and scanning capability of the printer.
- insert the disk in the CD-ROM drive - hit install - reminder:do not plug in the USB cable yet unless you are prompted by the installer to do so - after installing the software , make a test print to prove the functionality of the printer. - then we move on to test the scanner -there are two ways to make a scan: 1. click on the solution center icon on the desktop. 2. in the solution center , there are two buttons for scanning: scan pictures and scan document 3. scanned documents are saved under the MY SCANS folder. file path is : my documents or simply documents---->MY SCANS 4.for scanned pictures file path is
my pictures or simply pictures---->MY SCANS
Jun 27, 2011 | HP J3680 Officejet All In One Printer
When i scan an item through my scanner, how do i retreive that item or save the scan to my pc.
During scanning normally the program asks you where to save your document. Anyway your document can be under documents folder or under Image folder.
Mar 10, 2011 | Computers & Internet
I push the power button and nothing happens. It happened previously and a few days later I pushed the button and it came on as mysteriously as it went off. What can I do to troubleshoot or fix the...
Depending on how long the power was off, your desktop power supply circuit capacitors may have fully discharged during the power outage. This will effect how fast your computer will turn on when you press the power button. Turning off the power by pulling the cord, or a power outage while the computer was on will usually result in a message that Windows was not shut down down properly when you try to restart it. Also make sure your computer isn't plugged into a 'switched' receptacle that's wired to turn on a table lamp etc from a wall switch. It's usually the bottom half of the receptacle that's switched while the top plug is always 'hot' or powered and unswitched in a wall switch controlled recepacle situatation.
Jan 16, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I scanned a document & now can't find it.
Hi kathy_skip
If you remember the name of the saved file, use a search.
Some scanners give the name like scan000,scan001,scan002 etc
If you have no idea what the name was, then scan another document (if you don't have the previous one) and watch the name of the file and folder where it is saved. You may find your previous scan next to it in the same folder.
Best of luck
luciana44
Oct 08, 2009 | Brother HL-2040 Laser Printer
Hp deskjet f2280 need help scanning
this is a two step process first you scan the image and save it, usually you can find it under my scanned images folder, desktop, my documents, or use the search functionality to find your scanned file. For mor information about scan settings visit:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01567026&lc=en&dlc=en&cc=us&product=3390947&lang=en
you can then just open your word, go to Insert, picture, from file and browse to previously saved scan file.
Hope this answers your question.
Aug 30, 2009 | Office Equipment & Supplies
I'm trying to use the scanner to scan some documents and store it in a folder in the computer. Can you help me with this? Ray
Your software will usually ask where you want to store the document once it's scanned. A lot of software is intuative enough to guide you through each step.
Aug 19, 2009 | Office Equipment & Supplies
Toshiba e-Studio 205 Copier Logo
144 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
