Digihome digital terrestial receiver Model DVB 915 I sitched the TV set off at night and then turned off the electric switch at the wall socket for both the TV and Digi Box. Next day the digibog Digihome would not work - the red light on the digibox would not come on either which indicates ne electric supply. The plu fuse is ok. Can I make it work again or is it now U/S?? Please Neil Vaughan
  • Televison & ... Master
  • 1,525 Answers
Hello make sure power is off take the top off the digibox see if you've got a glass fuse inside if the fuse is black its blown .where the fuse is holders is it should say what the fuse is rated at ie 1.25 amp put a fuse in with the same amps if it blows again then you have a dead short in the circuit good luck
shaun
Posted on Jul 21, 2009
Is it a digital television or do i need a converter box
A digital tv would usually have the digital logo printed somewhere on the outer case. In Europe digital tvs are marked DVB-T which means Digital Video Broadcasting - Terrestial.
Whether your tv has such markings or not the menus should make it plain what sort of tv you have when you get it switched on.
Feb 24, 2016 | Viore Televison & Video
Autosetup on my DVB is not picking up stations. The TV is connected directly to the satellite dish and has all free sat stations. As far as I can see all the connections between the TV and DVB are as
I'm wondering where in the mix is your satellite receiver? The recorders currently on the market aren't able to decode digital satellite signals. They are capable of decoding cable but i'm unaware of any that work on satellite.
Sep 17, 2014 | Panasonic Televison & Video
Proline lvd2286wd tv
Check and replace its tuner. It is faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 16, 2014 | Televison & Video
Digihome tv
It's probably checking for firmware updates. You may be able to turn this off in the menus, but you would then need to manually check for updates occasionally.
May 06, 2014 | Televison & Video
Hi i have digihome tv but when plugged in there is nothing
First plug a other thing in the plug on the wall if it comes on then you know it's the tv power is a problem it could be that the power supply's has popped also there should be a button on the side of the tv some ware press it in or on make sure there
May 02, 2014 | Digihome Televison & Video
Does a samsung dv3 tv have freeview
Yes, it does.
DV3 is actually DVB meaning Digital Video Broadcasting. The stylised design of the DVB symbol makes it look more like DV3. If the TV has the DVB symbol, then it has a digital tuner and can receive digital channels, i.e. Freeview.
If you need assistance with tuning the Freeview channels or have further questions, please let me know the model number of the TV. This can be found on a label on the back of the TV.
Regards,
BElectric
Apr 24, 2011 | Televison & Video
No instruction to set up the freeview box digihome dvb 915 can you help
Set up should be quite straightforward assuming you have all the bits.
You will need
  1. a standard co-axial aerial lead from your TV antenna to the female socket on the Freeview Box
  2. A scart to scart lead to connect the Freeview box (tv out socket) to the television.
If you wish to connect a video recorder or other equipment you may also need a second coaxial lead (male to female) for the RF through socket to connect to the aerial in socket on the video recorder.
If your TV does not have a scart socket you can connect the scart lead to the scart socket on a video recorder and then use the normal method of watching videos to view the Freeview TV pictures (here you may need to press the PAUSE button on your video recorder to prevent it going back into standby-mode after a few minutes).
Simply connect the box to your TV, turn on the power and the auto channel-scan will immediately detect and install all available channels.
If the Freeview box has been previously used in a different location / with a different TV transmitter you may need to re-tune it. Press the menu button on the remote control, scroll through the menu to set-up. Follow on screen prompts.
Feb 09, 2011 | Televison & Video
I have an ADSA DVB-T Digital Set top box model MDS-V3 last night whilst watching it it just switched itself of and now there are two very dim lights on the front one green one which says locked and the...
Hello I have a dvb- t box. Mds-v3 modle butthe remote control has died I put in new battery's but no good i am looking for a replacement remote control is there any.place I can by a replacent remote control or has any body out there go one and how much is it to bye
William laing. Sheffield area
Sep 25, 2010 | Televison & Video
I have a Digihome DV940B freeview receiver, and wish to set it up with a tv and video how and where do I put the areal and scart leads
This depends on how you want to use your kit, and how many scart plugs you have in your TV and VCR.
If you have 2 scarts in your tv;
Aerial coax goes to digihome aerial in. Aerial out from digihome to aerial in of vcr. Tune vcr into Digihome.
Scart plug from digihome to tv.
Scart plug from vcr to tv.
You can then record what you have selected on your digihome box.
In my humble opinion, it's worth splashing out on a pvr; you have more functionality such as being able to record 1 program and watch another.
Regards
Zahc
May 05, 2010 | Televison & Video
Televison & Video Logo
179 people viewed this question
Top Televison & Video Experts
Electro Med Services...
