Question about Dishwashers
I am trying to plumb in my dishwasher but the water wont drain away
  • 297 Answers
You must make a connection at the sink drain,you can get the fitting you need at home depot, it is called a dishwasher tailpiece. you may have to drill into the cabinet the sink is on.
Posted on Jul 21, 2009
My dishwsaher wont drain water
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Aug 10, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Electrolux professional series not pumping water
Aug 08, 2012 | Electrolux Frigidaire Professional Series...
My Frigidaire dishwasher has dirty water.standing in bottom. Dishes are not clean
Aug 08, 2012 | Dishwashers
Standing water in dishwasher
Jul 30, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Jul 20, 2012 | Frigidaire Dishwashers
It washes the dishes but the water wont go away i have cleaned the filter and surrounding area but water wont go away any ideas please thanks
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 05, 2010 | Indesit Dishwashers
AEG Favorit 8081 displays error F0 - there is a build up of dirty water which has not drained way. I syphoned all the water away and after a while the dishwasher started to work again - but then the...
Hello. When the water does not completely drain away, it usually means that there is a partial blockage in one of these areas:
1. The small drain pump located under the tub, accessable by removing the lower front panel.
2. The drain line going from the DW pump to the plumbing under the kitchen sink.
3. The garbage disposal, or the trap under the sink.
Check these out and you will find a chunk of bone, or glass or some other debris which is partially blocking the draining action. J.
Sep 04, 2010 | AEG 24 in. Favorit 80800 Free-standing...
Water left in the bottom of a hobart (kit aid) dishwasher
Drain valve not opening, kinked or blocked drain hose. Remove the hose from the sink plumbing and look for debris. try running the drain hose into a bucket to eliminate a domestice plumbing issue, but hold onto it when it starts draining, or you will have a wet kitchen. Timer contacts may not be opening drain valve.
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water in the dishwasher after the the cycle is complete
Nov 19, 2008 | Whirlpool 24 in. GU1200XT Built-in...
Hotpoint dwf 30 - Water wont empty
if the drain is plumbed into a spigot on the sink trap, then this spigot is blanked off to prevent water coming out when you empty the sink. remove blank
Aug 31, 2008 | Dishwashers
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
