Question about Panasonic DMR-E55 DVD Recorder
Dvd model DMR-E55
My player is stuck in 'self checking' mode and will not open the disc drawer to remove a disc
  • geoffrico May 22, 2008
    on startup self check goes on forever never stops have tried holding variouse buttons on startup no good after a lot of trial and error i am shure it is the small circuit board to the left of the DVD recorder that actualy connects to the DVD by small ribbon cable that is faulty only way to be shure is to get one and try it {wish i knew where to buy one}
    Good luck
  • 28 Answers
IC001 STRG6353 on power board may be faulty, mentioned also in several other threads.
Available from various suppliers.
Posted on Nov 21, 2007
2 Suggested Answers
  • 979 Answers
SOURCE: DVD recorder DMR-E55
Describe "self check" mode?...accordianman
Posted on Nov 26, 2007
My dvd player has suddenly stopped being able to read any of my dvds and I can't work out why. The problem occurred after removing a dvd, the disc drawer would not close. So I switched the power off to the...
Your dvd's lens might have been damaged so try to get a new lens and then start it.I am sure that it will work again.And if you want the manual then you need to go to the below site and download it
If you need any further assistance please feel free to contact me again.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 22, 2010 | Panasonic DMR-E55 DVD Recorder
My panasonic dvd model DMR-55 won't turn on and the digital clock is not even working when I plug it in. How do I get the dvd in the machine out?
My Panasonic is stuck on self check when a new DVD is inserted?
It turns on and other functions are in-accessible during this self check
Any help greatfully appreciated.
Feb 15, 2010 | Panasonic DMR-E55 DVD Recorder
My machine goes into self checking mode and gets stuck.
If it's going into self-checking then either there is a problem with the drawer deck mechanism not being able to communicate with the logic board, hence the reason it stays in the self check. Contact your local Panasonis dealer to arrange a service engineer to perform a software update on the recorder as your current software could either be an older version or has been corrupted & needs to be updated.
Sep 05, 2009 | Panasonic DMR-E55 DVD Recorder
Self check will not stop
This is very common, please see my earlier posting which will tell you how to repair it, by clicking the link.
DMR E55 Self Checking Repair
Best wishes
Mar 21, 2009 | Panasonic DMR-E55 DVD Recorder
Will my non finalzied discs play on a panasonic ez 28 or ex 768
You will have no problem playing your non finalized discs on any of the Panasonic DMR range including the DMR EZ28 series. The DMR E55 can also easily be repaired if you can use a soldering iron and a little care. Please checkout my other postings for full repair details.
Oct 08, 2008 | Panasonic DMR-E55 DVD Recorder
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
I have a Panasonic DVD Video recorder Model DMR-E55 and when it is turned on it just loops on the start up self check process and never fully boots up. I am wondering if the disc drive may have failed (I...
I took it to the Panasonic service centre is Auckland who replaced the power card, cleaned the RAM disk drive and updated the firmware all within the $55 Diagnoses fee.
Apr 21, 2008 | Televison & Video
DMR E55-P will not read DVD-R
Hi Benyto
Thank you for the information. Sorry that you are having such problems.
Nearly all the problems on ths DMR E55 are due to a faulty power board. The greatest load on the power supply is when the unit first reads discs and also when finalizing. Sometimes the unit cannot read discs and sometimes it continuously self checks.
Try replacing IC001 on the power board. This is a 5 pin regulator #STRG6353. This component gets very hot and the heatsink is poor. When I replace these, I use a larger heatsink and some heatsink paste which helps to prolong the life of the component. If you look at the regulator, you will see by the colour of the circuit board that it gets very hot. It fails after two or three years in all DMR E55s.
Be careful when you take the old regulator out because the print can lift away from the circuit board.
I have posted full instructions on how to replace the STRG6353 >HERE<
Hope this helps
Mar 02, 2008 | Panasonic DMR-E55 DVD Recorder
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
280 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
