Question about Intermatic & Indoor/Outdoor Rain Tight Timer
The actual timer is not advancing it is just clicking?
I have to manually turn it on and off with the toggle switch - the actual clock (round yellow) wont advance ot push in or pull out:
  • 53 Answers
Pull the yellow part out alittle and turn it so that it will catch a gear
Posted on Aug 02, 2009
Clock on T1905 timer switch has quit working. Fixable, or need a replacement?
120Volt T1905 Intermatic timer uses WG730 clock motor and 156T1950A tripper.
Timer will last many year by replacing parts, and keeping lubricated with touch of white grease, and not over-amping the 20 amp contacts
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T1906-Intermatic-timer.html
http://waterheatertimer.org/How-to-replace-Intermatic-clock-motor.html
This timer can be converted into 208-277Volt timer by installing WG733 clock motor instead of 120Volt WG730.
Nov 13, 2012 | Intermatic Timer T1905 24 Hour Dial 120V...
I just replaced my pump and rewired it exactly as it was on my other pump. The pump works when I click the breaker on the power panel but the intermatic timer no longer works. Its like it skips it. No...
Question posted under R8806P101C 240Volt sprinkler timer.
With different timer, add a comment for possible help:
Open following links to identify timer and replacement parts, and see typical manual:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/r8806p101c%20-%20english.ashx
http://www.intermatic.com/products/ec%204%20layer/mechanical%20time%20switches/specialty%20time%20switches/r8800%20and%20t8800%20series.aspx
Your timer is stuck ON.
Temporarily disconnect ground wire at pump to make sure short is not somehow completing 240Volt circuit.
Move toggle switch to Auto position, and then ON and then OFF > Toggle should be able to switch Load on-off. If toggle is problem, then order 133T1115A switch.
Note if the timer dial is rotating and keeping good time: if dial is not rotating, then replace WG733-14D clock motor.
If dial is rotating, the trippers might be worn down. Order 156T1950A trippers.
If dial is rotating, and trippers are good, then relay might be bad. Order 143T139A relay.
Add a comment and say what you discover.
Aug 22, 2011 | Intermatic R8806P101C -...
I just installed a Wood 59018 timer, and when i try to turn it on manually, I hear the relay click on and then immediately off (the attached light turns on and off too). That's when the switch is set...
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Jul 09, 2011 | Woods InWall 7 Day Digital Programmable...
Intermatic t104p3 pool timer will turn pump ""ON" with Manual Switch but will not shut "OFF" using Manual Toggle. Pool store showed me how to remove and look at the contacts on...
Thank you for including model number so answer can be accurate as possible.
T104P3 timer works with manual override so timer is basically sound.
Clock dial rotates and keeps good time, so WG1573 240Volt clock motor is good.
Trippers do not click on-off lever, so trippers are suspect.
Trippers are made to wear down so that timer mechanism lasts years longer.
Order extra clock motor and trippers at Grainger
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
See wiring diagram:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 18, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I having troble with my t103 timer to turn the lights on manualy i try to set the timer but for some reason doesn't work what can i do ???
T103 Intermatic timer has 120Volt clock motor and can control 120V or 240V Loads.
Wiring for timer is shown on following link:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
Troubleshoot T103:
1) Manual override is working correctly, and it snaps crisp and clean, and Load turns on-and-off.
That means timer is basically good.
2) Next look to see if yellow dial is rotating.
If dial is not rotating, then 120Volt clock motor needs to be replaced.
Take photo of wiring and mark wires before starting.
Remove two white wires connected to screw terminals 1 and A.
Snap timer mechanism out of box, clock motor is on back of timer.
Use small star screwdriver to remove old clock motor.
Reattach white wires on terminals 1 and A, tighten screws very tight.
Reset current time: lift and rotate dial until current time lines up with silver pointer.
Grainger sells 125V clock motor:
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
3) If dial is rotating, but gets stuck at certain times, or runs slow, then replace clock motor.
4) If dial is rotating, and trippers are attached to dial, but timer does not turn ON, then trippers are worn down and need to be replaced.
Grainger sells the T103 trippers
http://www.grainger.com/Grainger/INTERMATIC-Timer-Tripper-2E054?Pid=search
5) How Intermatic mechanical timers work:
Dial with ON-OFF trippers is rotated by clock motor.
Trippers on dial contact ON-OFF lever.
ON tripper pushes lever one direction.
OFF tripper pushes lever opposite direction.
Lever moves electrical contacts on back of timer that turn Load ON-OFF.
Manual override lever clicks back and forth with each ON-OFF action.
Nov 20, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
The yellow time dial has stopped turning and the auto switch cannot activate the sprinklers
If I understand correctly, the manual override does not work, and the clock dial does not turn.
It seems odd that both things would happen together. Usually the clock motor stops but the manual override still works.
Check that your timer has electricity. Check your breaker. It sounds like the electricity is off.
Does your manual override snap clean and crisp, or it it sluggish? If the manual override is sluggish, the timer mechanism may be rusted.
Snap the timer out from the box and look at the condition of the gears, and the override lever. If the timer is rusty and the manual override does not snap clean and crisp, then the timer needs to be replaced. Buy a new timer and swap out the insides without changing the box.
You might need a clock motor
Snap out the mechanism and get the number off clock
Intermatic site shows pages of clock motors: They are priced high, but cheaper than new timer.
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Aplus supply sells assortment of Intermatic clock motors.
http://www.aplussupply.com/intermatic/timermotors.htm
To search these pages quickly for your clock numbers, use browser Find (Click edit at top of bowser, click Find)
Intermatic has a page with manuals:
Open page, click plus next to timers and scroll down to sprinkler and irrigation timers
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
It's good to have the manual on hand in case the product is discontinued
Nov 09, 2010 | Intermatic R8806P101C -...
Clock does not work to turn pool filter on and off. do I need a new timer mechanism or clock motor
Things to check:
1) Is yellow dial rotating? If not, then clock motor is probably bad. T-100 240V time clock motor sells for $16 at grainger.
Also timer may not be getting 240V so check manual override.
2) If clock motor is turning, but manual override never clicks on-and-off, then pins are probably worn out. Buy pins at grainger
3) Does manual override work? Does it click crisp? If manual override clicks crisp on-and-off, and pool filter turns on-and-off normally, then a) the circuit is getting 240V and b) the timer mechanism is ok ... so clock motor is probably bad.
4) If manual override snaps crisp but pool timer does not turn on, then then circuit breaker could be bad, wire is loose, motor has gone bad
Test for 240 across poles 1 and 2
... or timer contacts are worn out & you need new T-104
See back of mechanical timer
5) If manual override is loose or sluggish, then you need new T104. You can buy a T-104, T-104R, T-104M etc ... and the interior body will snap into old box.
Note: Do not buy T-101 or T-103 as these have 120V motor.
Sep 29, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Once T101 Timer Shuts Off will not turn back on
you have the hot and load reversed. the power source should connect to terminal 1. the wire going on to the pool pump should be hooked to terminal 2.
the clock motor is powered off terminal 1 and A is the neutral.
what u have done is hooked the power source to #2 and the load to #1, simply switch them and everything should be fine, here is a link to the wiring diagram for the timer.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t101%20-%20english.ashx
Aug 22, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
How can we turn off the automatic start of Radio or CD setting?
The activating and deactivating of the 24 hour timer is via a toggle button, labeled "TIMER" on towards the right side of the top console. When the TIMER is activated, you will see a small clock symbol on the LCD display. While the unit is on, tap the TIMER button once. The clock symbol will disappear and the timer is now off.
Reactivating the timer is the same process (remember, the button is a toggle). Tap the TIMER button and you'll see the timer settings show up on the display (time on, time off, source, and volume). The little clock symbol appears again.
If you have lost your manual, you can download another one for free from this location:
http://www.retrevo.com/s/JVC+SD1000
Nov 17, 2008 | JVC FS-SD1000 CD Shelf System
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
379 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
