Question about Samsung Digimax L60 Digital Camera
Overexposure on Samsung Digimax L60
My Samsung Digimax L60 has been working fine for 2 years but it suddenly started taking overexposed photos especially when outdoors. Its ok when you preview it and the movie mode takes perfectly good videos but when you take a photo, it goes white. I've tried all the flashes, every single mode and manually adjusted the ISO and white balance but its still taking white pictures.
  • Anonymous Mar 21, 2014
    I have tried all settings but can't alter the exposure. Is the shutter sticking?
Had same problem after 2 years. Took it in to a repair shop & they installed a new camera flex. Its working OK now.
Posted on Sep 09, 2009
Pictures are over exposed when outside
You may have the settings wrong. Check in the MENU to see if you have it set to "inside" pics rather than outside.
Also the ISO has a lot to do with the exposure. If the iso is set too low outside sunlight pics will be white or overexposed. Try setting ISO on wheel for various options select program mode button and MENU select ISO 120 or 250. These are are pretty general settings. the flash will only engage inside or outside if the light is low ( like evening) I suspect your ISO setting is at a setting that is incompatible with bright sunlight
t
Also select White Balance and move it to DAYLIGHT
take a few shots inside and out to see if there is an improvement.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Samsung Digimax L60 Digital Camera
How do you transfer internal memory pictures to memory card? I have a Samsung Digimax L60 camera and I forgot to put my memory card in my camera and took pictures without it in. How do i transfer the...
Put the memory stick inside the camera. Then open the photos which is save in your camera memory. Select them all & then you find a option Send to memory card or copy to memory card. Select that and press ok. Your photos transfer from camera memory to memory stick.
Thanks
Dec 30, 2009 | Samsung Digimax L60 Digital Camera
Overexposed photos in otherwise normal settings in casio ex-s500
It is the shutter (or at least it was for me) I found a simple test here: http://www.mydc.com.tw/repair/knowledge_en/casio-exilim-ex-s600-overexposure-t17.html
I repaired it myself, but it took me a whole afternoon and lots of patience.
The hard part is taking the camera apart, once I got to the shutter I just activated it manually so to dislodge any pieces that might have gotten jammed, then placed it back together again and it worked! :).
It's really hard to take apart, it's like a puzzle sometimes, to find which screws are keeping it together. I also had a bit of hard time when it came to put the zoom back together again.
But I guess it beats throwing the camera away.
I'm still puzzled on how the CCD works so that an overexposure would make horizontal overexposed lines, but everything points to that. Fixed shutter, lines be gone.
Apr 29, 2008 | Casio Exilim EX-S600 Digital Camera
Camera overexposes on daylight and recorded images have hoizontal striping
I would take it off of automatic mode and adjust it manually.
The Samsung camera I have doesn't work very well in automatic mode under indoor conditions. It will work in automatic under outdoor conditions.
Hope that helps.
Mar 24, 2008 | Samsung Digimax L60 Digital Camera
Digimax L60 will not recognize my card
Your Digimax L60 will also recognize your SD card please select the option to save pics
In camera or in memory card. This time your camera work on its internal memory.
Oct 11, 2007 | Samsung Digimax L60 Digital Camera
Overexposure
CoolPix 5700's have a common image sensor failure. Check with Nikon for recalls, this may be the cause of your issue. Alternatively the shutter may be stuck open, causing too much light to reach the sensor and causing over exposure as well as lines across the image. David Millier Advance Camera Repair
Mar 11, 2007 | Nikon Coolpix 5700 Digital Camera
Samsung Digimax L60 Digital Camera Logo
660 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
