The install is fairly easy. Before you begin make sure if you have SCSI adaptors installed have the drivers for them on hand. If you do not have these drivers you should download them to a 1.4MB floppy disk. When you are ready, put the Windows Server disk in the cd/dvd and reboot the IBM. Follow the instructions on screen and you shoud be fine. From start to finish it should take you about 1 1/2 hours to complete everything.
My started after I opened the case to add a tape drive. Now the fans are going full blast? Is there...
(More)
My started after I opened the case to add a tape drive. Now the fans are going full blast? Is there anyway to control these things?
Fails in selectApplicationLogAction method validation...
(More)
Fails in selectApplicationLogAction method validation error_entrust_password,ArmouredStreamException:A connection with the Directory could not be opened; IP/port may be invalid or the Directory may not be running,
how to use raid or mirroring ina ibm x 3400 server system ,it has 2 hdd of 250 gb,and work with...
(More)
how to use raid or mirroring ina ibm x 3400 server system ,it has 2 hdd of 250 gb,and work with windows 2008 serevr
hi i have ibm x3400, even thought i have installed update ethernet drives, it takes much time to...
(More)
hi i have ibm x3400, even thought i have installed update ethernet drives, it takes much time to save data, i am unsing oracle ,knidly give a soultion
