I can't get my HP Pavilion to recongnize my OfficeJet All-in-One or Fax to work.
  • 6,784 Answers
HI, if not done so already, you will need the correct drivers installed for the CPU to actually recognize this All in one unit. use the link below to be directed to the HP driver base download page. once you click the link below, you will be quickly directed to the driver page. There are two steps on the support page that you will need to follow in order to receive the correct updated driver pack for your unit. On the first step, you will need to select the appropriate task. Select (download software and driver). After you have selected this , move on to the next step. Step 2 consist on inputting the actual product name into the blank(Example--Office jet ALL-IN-ONE). once this is done, just click go and , you will be directed to the download pages. which, will contain all necessary drivers and software that you will need so that your CPU will recognize this printing and faxing unit(all in one).
CLICK HERE TO GET STARTED
***NOTE(If you can verify that you have the appropriate and current driver base and software installed at this time and, the CPU will not recognize the ALL in ONE unit, i recommend inspecting the USB cable for faults. inspect the USB ports on the cpu as well. replace the USB cable if found to be faulty).
Posted on Jul 21, 2009
  • Michael Masters
    Michael Masters Jul 21, 2009
    Be sure to include the product name and number in the step 2 space provided.
I want to fax a document
Hi
To send a fax from your hp officejet
Follow these steps to send a fax from your HP OfficeJet.
1 Load your original.
Note: You must use the automatic document feeder (ADF) for multi-page
faxes.
2 Enter the fax number using the keypad.
3 Press Start Fax, Black or Start Fax, Color.
Oct 26, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I want fax a document
Hi
faxes.
pls vote me i help you
OfficeJet 9120 All-In-One InkJet Printer: hello The fax in my hp officejet 9120 is not w...
According to the manual found at support.hp.com, you need to go into the setup menu for faxing and enter the necessary information prior to faxing.
May 16, 2010 | HP OfficeJet 9120 All-In-One InkJet...
Hp Pavilion does not recongnize cd drive
if you have an os cd , put it in the drive , restart the computer and see if it tries to boot from the disk. If not its proly a physcial problem with the drive
Dec 06, 2009 | HP Pavilion dv9000z Notebook
The fax in my HP Officejet 4110 all-in-one is not working.
you have not installed the printer at your PC.pls installed the printer.
Sep 30, 2009 | HP Officejet 4110 All-In-One InkJet...
FAX
If you have fax on hp officejet 5610.
You can recive fax .
start>steeting>printers and Fax> Setup Fax.You need windows XP CD for this Fax installation.IF manufacturer given software u r not need to install again.Just review the fax configuration by rigt click on fax icon then go to properties.
IF it helps
pls RATE ME
Jun 25, 2009 | HP Officejet 5610 All-In-One InkJet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
22 people viewed this question
jasbo
jasbo
