Related Tags:
This problem should be removed because:
Problem with Tomtom GO 700 GPS Receiver
TomTom GO 720 - flashing red circle with white cross on screen
I have a GO 720 and when turning it on I get a screen with a flashing red circle with a white cross... I have reset it and downloaded updates but it hasnt recified the problem. Any ideas???
Solutions (5)
Best Solution
Hi, I am back, just got the problem solved, I called their tech support at no charge (866-486-6866, Glen) , really good service.
First turn your firewall off (if you have one). You need to go into your 720 with the TomTom Home software and erase the downloaded software (with the remove items from my device) and reset the device (little reset button under the unit keep it pressed for 5 seconds), place it back in the cradle and restart your computer and than restart the 720 , bring the TomTom Home program up, and when the TomTom Home software in your computer restarts and detects the 720 it will tell you that you need to update the application, if it doesn't than you force the update by going to the add maps option, select items on my computer, select applications and press the add button, when done, go back and to device (option in top of your screen) and select disconnect device, restart your 720 and it should be back to life with the upgraded software.
Hope this helps
Aldo
fix it
hi i got a tom tom 720 and im getting a red corss any ideas from roy in leeds
If i did not make a backup (like an idiot) before trying to do the update.. Any chance of re-programming it or something.. All is lost..
Chad
Ladner, B.C.
Hi guys
I had the same problem, I have just received my new TomTom Go 720, done updates and.....white cross on red circle flashing with the next start up.
I have spent the whole Saturday evening and the whole Sunday trying to fix the problem. I went through every post on different forums and tried different thins including: formating device, reseting it, coping files, pasting files, dozen of installations using old and new version of Home Software.
I have done literally everything I could following other people advises. Nothing worked. All I managed to do was to get to the stage where red circle does not appear anymore but it got stuck with on the start up showing me either black screen with TomTom on it or the screen with the crossroads.
Sometimes It let me chose what map I want to use but after that it rested itself continuously.
But finally I have solved my problem and my device is working as it was originally.
I need to underline that I have done backup before I downloaded updates BUT after restoring that backup using HOME2 it did not help.
What I have done is very simple. I went to the folder where my backup is kept and copied and pasted all the files from there onto my device.
it worked!!! Something tells me it could be also something to do with the map i updated as after i done some fixes it let me chose the map but did not go any further. This was the first time when I pasted previous map and it worked instantly.
Good luck guys.
GO 910 Cannot remove flashing white cross in red...
Can you help me remove the flashing white cross in the red circle as it won't let me get into the maps. I have tried to reset several...
i have a tom tom
i have a tom tom 720 after connecting it to my computer. it will not turn on a white cross in a red circle keeps flashing
TomTom GO 720 - flashing red circle with white...
I have a GO 720 and when turning it on I get a screen with a flashing red circle with a white cross... I have reset it and downloaded...
screen deactivated & a red circle with an...
screen is deactivated and there is a red circle with a white 'x' on the middle. the circle is flashing. opposite the flashing circle...
Add Your Solution
my go 700 has lost all its settings nothing...
my go 700 has lost all its settings nothing showing just a blank screen started upgrade it said upgrade complete turned...
traducere meniu tom tom go 700
vreau limba romana
Fix-O-Meter
5,595
5,595 people viewed this problem
- 6 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Tomtom GPS Device Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
