Question about Garden
Where do the 2 wires that go's to the points go
Where do the 2 wires that go's to the points on a 3 hp briggs go I know the one from the coil gos to the condensor but where dose the ground wire go. Thanks
  • 1,000 Answers
The condensor and negative coil wire both attach to the contact points. When the points are closed the ignition coil charges ( sota speak) and when the points open, the coil discharges a spark to the spark plug. The condensor is an electrical "shock absorber", it smooths out electrical spikes.
Good luck, make sure the point gap is correct.
Regards,
Posted on Jul 21, 2009
Were is low oil sensor 13-hp.briggs
check gap on coil the gap on the points and also make sure the magnets are free of rust, the capacitor could be weak also.
Jun 11, 2014 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a 20 hp briggs and stratton that wont get any fire
Check the diodes in the wires to the coils. Trace the wires from the coils, and they should join together into a single wire. In the junction of the wires, there is diodes. There is a possibility the diodes burnt out which will not allow power to the coils. My experience was when one burnt out and only one cylinder would run. I replaced the wiring and both cylinders worked fine.
Jan 30, 2013 | Briggs & Stratton Briggs Stratton Intek V...
18 hp briggs and stratton no spark
unplug oil senso still no spark un \plug shutoff wire to coil still no spark replace coil
Nov 15, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton motor w/ points 5 or 8 hp. withintermittent spark. i checkep points and cleaned. gap looked good. checked coil wire, no cracks or shorts. cleaned mag mag and coil pickup. checked ground...
If selled some capacitor or new ignition parts order it always with statement of the serial motornumber and the year of build , because of modifications on marketing technical dicisions can be made for your engine, that can prevent a next disappointment. may be for the problem a new sparkplug the supression capacitor can also be bad a bad sparkplug connection cable .are some small sugestions.
Jan 26, 2018 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a 8 hp Briggs with electric start.Battery is dead it also has pull start. Hasn't been started in a while cannot get fire from plug.Not sure what to try next.
1 - a bit obvious, but make sure you have the switch turned to on
2- replace the plug
3- If there is still no spark the magento coil may be expended and require replacemt - check to see that the
wire from the plug to the magento coil is not earthed / grounded
Dec 16, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Have 303447 briggs 16 hp only fires one cylinder
Have you also changed the spark plug too. The ignition circuit is pretty simple, from the battery, the Coil is energized, the "points" or equivalent, through the "Distributor" or equivalent, and onto the Spark Plug. So it is a simple matter to work along the path, proving the "Integrity" at each, point by testing. IF it still doesn't fire after ensuring all Leads are OK, the Spark Plugs are proven OK, the Cables, the Points, & Distributor, . IT is either that or the Ignition Timing is OFF. Please check all those points.
Apr 23, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
8 hp briggs no spark,new coil ,new electronic
make sure the plug wireisn't grounding on sheet metal. Verify current to ignition module and that module is securely mounted for grounding. Negative side of coil to module, pos to ignition switch or starter button . Chk for current at coil +. . Coil -- should pulsate when cranking. Ensure there are no inline fuses, fuse box fuses, or fusible links incorporated into wires lesding to module. Good Luck_Ned_
Oct 31, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Where does the wire go off the points?
wire goes to the coil.condenser lead is attached to the same connection on the points.
Oct 01, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Cant get a spark on my briggs and stratton 4hp engine, trying to
gap from coil to flywheel is .010. if you've replaced coil, points and condenser with no spark i would try replacing the coil and points with an magnetron kit or a coil that allows for the elimination of points.
Mar 21, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
