Question about Microsoft Windows 2000 for PC
Bsod when i tried to install win2k
I encountered the message Pafe_fault_in_nonpaged_Area when i tried to reinstall windows 2000 after i reformatted my HD.
  • 1,601 Answers
This Stop message occurs when requested data is not found in memory. The system generates a fault, which normally indicates that the system looks for data in the paging file. In this circumstance, however, the missing data is identified as being located within an area of memory that cannot be paged out to disk. The system faults, but cannot find, the data and is unable to recover. Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
User Action:
This Stop message usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, either main memory, L2 RAM cache, or video RAM). If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. Run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owners manual for your computer. Another cause of this Stop message is the installation of a buggy system service. Disable the service and determine if this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows 2000 Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time. Antivirus software can also trigger this Stop message. Disable the program and determine if this resolves the error. If it does, contact the manufacturer of the program about a possible update. A corrupted NTFS volume can also generate this Stop message. Run Chkdsk /f /r to detect and repair disk errors. Restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk. Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver causing the error. Disabling memory caching of the BIOS might also resolve it. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at
Posted on Nov 21, 2007
Page in fault in nonpaged area
you have a faulty RAM. try switching it with a new one, it should solve your problem
May 23, 2017 | Acer Aspire One Netbook
Hi, i'm having problems with my pc. ive got it out of asking me the system password and when it starts it says a problem has been detected... on a blue screen. how can i get rid of this???
That is the BSOD - it appears when the system has encountered a fatal error and has crashed.
I think it's time to reinstall Windows, it will be a lot quicker and easier than trying to fix the origin of the BSOD.
Jul 17, 2011 | Dell Dimension 3100 PC Desktop
Having trouble playing a game .game will start but two minutes into the game will get a blue screen stating a problem has been detected and windows has been shut down. message: the problem seems to be...
This is a problem with the drivers for your motherboard video. You need to download and install the latest intel video drivers from your PC Manufacturer. Intel has "locked" them so you can only use the ones from your OEM PC Vendor.
Apr 17, 2011 | Computers & Internet
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
Dell Lat d620 duo: ran a full system scan yesterday as I normally do for maintenance and got the BSOD. Message: page fault in nonpaged area. Tried all options to reboot, always eventually gets to BSOD and...
Take out the memory and replace with the old one.
If you have a 32 bit Windows and have more that 4GB RAM then you need to upgrade to 64 BIT.
This is the RAM you need:
Standard Memory : 256MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 533MHz (PC2-4200) 200-PIN SODIMM Notes :
Jan 06, 2010 | Dell Latitude D620 Notebook
Nvidia 6200 gap graphics card not recognized under WIN XP
DId you hook up the secondaary power supply on the side a 5 pin 1/2 inch in width?
Nov 20, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Page fault in nonpage area
Restart the Computer and keep tapping the F8 key for 5 to 7 seconds to display the Advanced Boot Option screen. On that screen, select "Last Known Good Configuration" option. Furthermore, if you've installed any new hardware then uninstall it.
Once the Computer is able to boot successfully, run "chkdsk /f /r" utility to detect and repair any disk errors.
Faulty hardware, a buggy system service, anti-virus software, and a corrupted NTFS volume can all generate this type of error.
Aug 29, 2009 | Computers & Internet
New XPPro Install... Can't see HD
Try to download a widows XP based driver for your Promise Controller from the manufacturer's website and install it. This is really necessary. If it does not solve the problem, you reinstall windows XP. When XP begins installtion it flashes a message like this: "Press F2 to install a third party driver......" Press F2 and insert the Promise controller driver in a floppy. This way it will work. (I hope so..) Note: Do not remove floppy untill Windows finishes installation
Sep 26, 2007 | ASUS A8V Deluxe Motherboard
Microsoft Windows 2000 for PC Logo
80 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
