Question about Panasonic DMC-TZ5 Digital Camera
The automatic lens cover does not retract (specifically the top half of the cover). The camera was working fine before this mysterious malfunction. How can I fix this? Thanks
  • nicklegrand1 Jul 21, 2009
    Is there some way to reset the camera settings that might work? How can I test to see if the lens cover is somehow stuck or jammed?
Hi there
Adjusting camera settings may not have an effect on the stuck lens cover.
When the lower cover is retracted, are you able to use your finger to pull the upper cover down? If so, does it stay in the closed position when you do it manually?
Thanks
nLinked
Posted on Jul 21, 2009
  • 11,896 Answers
This is a program with the firmware that has been happening to all kinds of digital cameras. Either the lens itself is sticking, or the firmware will need to be sent in for upgrade.
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out fine...except...it doesn't retract completely flush with the barrel of the lens. Is this a big problem?
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Aug 26, 2012 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Canon power shot SD1200 IS elpf won't retract
This is a delicate operation but you can try this: tap the camera lens up on a towel over a hard surface (counter top or floor) while you expect the lens to retract as in turning off. It may be enough jarring force to get cams back in the helix that moved the lens. Hit it hard and flat. IF that doesnt work, try tapping the lens down while it tries to retract. I have heard that people get so frustrated with it that they slam the camera lens up on a desk and that fixes it!
Jan 30, 2018 | Canon PowerShot SD780 IS / IXUS 100 IS...
My lens will shut half way, then turns off automatically. Once I turn the camera on. I Cannot take pictures. Any advice will help. Thank you
Hi Natalie:
Lens stuck, is common defective that need new lens unit replacement or just repairable.
Causes of a Lens Error: There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
How to Repair a Lens Error: As scary as a lens error might seem, there are some easy fixes. Before trying any of them out, however, first take a good long look at your camera warranty and maybe have a chat with the company. If the lens error will be covered under the terms of the warranty, go for it. Even some of the simple fixes mentioned below might void the camera warranty. Frankly, however, it's unlikely that a lens error will qualify for the warranty.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | Samsung Digimax S800 Digital Camera
Kodak EasyShare C513 lens cover will not open fully automatically. tap on side of lens and the baffles will open and camera works. turn camera off, lens retracts and baffles close. have tried blowing any...
I had a friend that ran into the same problem, but his solution is not what I would recommend but it did work for him. He used sewing machine oil and applied a tiny amount less than a drop to the crevice of the camera body and the outer lens housing, his was stuck in the retracted position, and he got it going again without a problem.
Jan 17, 2011 | Kodak EasyShare C513 Digital Camera
Camera model SL620. Lens cover does not automatically fully retract. A small portion blocks the top and bottom of the lens but will retract if touched. Tried blowing dry air on the cover and wiping with a...
Apparently the lens has had some kind of impact to cause the lens cover to be bent a little. What happens is that the lens cover holder , or ring, on the end becomes bent or misshaped to a degree. This then causes a binding effect on the diaphragm assembly.
What I have done is to very carefully (while using good magnification) pry up on the edges of the lens cover metal edging on the inside edges. This will release the pressure on the lens cover diaphragms.
But, be advised that this is can harm the lens cover more, unless you are extremely cautious. That means to use a small screwdriver or some such tool to pry up on the inside edges carefully.
Also be advised that too much pressure can cause the whole ring which holds the diaphragm assembly together can pop up and off. Then the whole assembly can come apart, and that is very hard and can be tedious to put back together.
Apr 15, 2010 | Cameras
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens won't retract
There are special springs, motors, gears, and guides inside these lenses.
If your lens won't retract, one of the above is bent, misaligned, or broken. There is not a 'quick fix' that can be applied in your situation since it is a physical problem, not a software malfunction. You can try to dismantle yourself but speaking from experience you are likely to make the problem worse. If you are unwilling to attempt repari yourself, either take it to a repair shop or upgrade.
Aug 18, 2009 | Cameras
My digital Sony camera fell down Lens got stuck
    As in short answer you have to replace the optical lens assymbly.Because due to heavy jurk its motor called sledge motor stsrt malfunctioning and it can not be changed component level. For this please contact any SONY SERVICE CENTRE nearby to you.
Hope you will understand.
Thanks for using FIXYA!
Apr 28, 2009 | Sony Cyber-shot DSC-H7 Digital Camera
Lens won't retract
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Jul 08, 2008 | Canon PowerShot S2 IS Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
Panasonic DMC-TZ5 Digital Camera Logo
123 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
