Question about Kenmore 73952 Gas Dryer
Dryer doesnt go on
My Kenmore 90 series make a buzzing when I hit the start button & doesnt go on. Is it the fuse?
I opened up the lower panel of my kenmore 90 and then removed the blower cover. I found two hair pins lodged in the blower and removed them. I tested the dryer with it open and the blower and drum began to turn again. I buttoned everything back up, and it is running fine now.
Posted on Feb 07, 2012
    Genius:
  • 1,122 Answers
Dryer motor worn out,will not turn over-mike
Posted on Jul 22, 2009
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Buzzing sound
This could be caused by vibration of the element coil supports (ceramic pieces that hold the element) as the machine is running. It could be intermittent due to the expansion and contraction of the coils when heating up and cooling down. See if moving the dryer while it's "buzzing" makes any difference in the sound.
If this is the case, you can replace the heating element or try re-leveling the machine. As a quick fix, tweaking the coil or supports is also possible but I wouldn't recommend this unless you feel comfortable doing so or you have experience.
Feb 15, 2009 | Kenmore 84052 Dryer
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
There is a clicking sound when you press start.
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Oct 20, 2008 | Kenmore 63942 Dryer
Kenmore Series 90, just buzzes when you hit the start button even though the cycle dial is in the center. What's broke or what can I test?
It sounds like a defective motor. You may be able to hand start to confirm this. You will need another person for this. With cycle selected and door open, hold in door switch lever. Have second person press start button. While button is pressed, give the drum a spin by hand and see if it starts up. If it does you may be able to dry a load or two. The motor will need replacement.
May 10, 2008 | Dryers
Kenmore 73952 Gas Dryer Logo
300 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
