Shieded cable running from the pc board to the scan assembly is worn. How do I order a new cable.
Order a new cable from Belkin.Com or equivalent. It would be a good idea if you specified USB-2.
Posted on Jul 21, 2009
Can i get a display screen for a sharp microwave model # R-530ES, and if you can provide this display, can it be shipped to miami?
The relevant service manuals are HTML clipboard here and here. hey contain detailed disassembly instructions.
There are three ways to get this fixed:
1. You could order a new power unit (lower board assembly) and a new upper display board assembly, solder them together, then replace your assembly with the newly assembled one.
You'd need the following parts:
DPWBFC167WRKZ CPU/LSI/display unit $107.07
DPWBFB094MRU0 power unit $53.09
Which can can be ordered from Encompass here.
2. This option is more difficult, but cheaper. You would order the upper circuit board assembly, desolder your old one from the lower power board, then solder the new upper board onto your power board.
You'd only need to order this part:
DPWBFC167WRKZ CPU / LSI / display unit $107.07
3. You could send your control panel assembly for repair for $39.95 with a one-year guarantee. Details are HTML clipboardhere.
Aug 31, 2010 | Sharp R-530ES Microwave Oven
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
Brother MFC-410CN
When you lift the scan assembly you will see 2 covers that run to the back of the machine, you lift those covers and unplug the cables from the circuit board and take this scanner assembly off. After that there are 7 screws to lift the center cover. You will then see the printhead with 4 ink tubes attached. Cleaning usually doesn't help this printhead, only a new printhead, around $100.00
Feb 17, 2010 | Brother MFC 420CN All-In-One InkJet...
395 Service Engine Error
Hello kieran,
This might help you. I found this on one printer forum.
From the manual:
Fuser Drive and Contact Cam System Service Check
Error Code 993: Indicates the cam sensor has not been activated.
The sensor activates when the fuser drive motor turns the cam disk.
If the fuser drive motor does not turn on, or the drive parts are not
operating, go to A.
If the fuser drive motor turns and appears to be operating properly,
and the cam is turning, go to B.
and the cam is not turning, go to C.
A The fuser drive system is not operating properly.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
Check the fuser assembly internal drive gears
for binding, or broken or worn teeth. If a
problem exists, repair or replace the fuser
assembly.
Remove the fuser drive motor from the stay
assembly, leaving the motor cable connected
to the motor. Turn the printer on, but do not
allow the motor to touch other areas of the
printer. Verify the motor turns during POR. If it
does, the problem is most likely in the motor
mounting stay assembly. Go to step 2.
Check the motor for shorts between the case
and each motor winding. If a short is found,
replace the motor.
Note: Damage to the engine board may result
from a shorted motor.
Check the motor for open windings. If found,
replace the motor.
Check continuity of the fuser motor/paper feed
motor/carriage unit motor cable.
• If incorrect, replace the cable.
• If correct, replace the engine board.
2 Motor Mounting Stay
Assembly
(Fuser Drive Parts)
Check the fuser drive gears, gears C3-1, C3-
2, the clutch spring, motor drive gear, gear C2
and C4 for signs of chipped gear teeth, worn
parts, or improper operation. If problems are
found, repair as necessary.
Check the cam gears and solenoid for proper
operation and signs of broken or worn gear
teeth or damaged parts. If found, repair or
replace the motor mounting stay assembly.
B The fuser drive system is operating properly and the cam disk is
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
Be sure the cam sensor is mounted correctly
and locked into place.
Check the following voltages on the cam
sensor:
Pin # Signal Voltage Voltage
Voltage Disc in Disc Out
1 (Orange) +5 V dc +5 V dc +5 V dc
2 (Brown) -CCSENS +5 V dc 0 V dc
3 (Green) GND 0 V dc 0 V dc
Note: The voltage on pin 2 should vary, as the
cam turns from approximately 0 V to +5 V dc.
• If the voltage on Pin 1 is incorrect, check
the cable. If incorrect, replace the cable.
• If the cable is good, replace the following
FRU's in the order shown:
1.Cam sensor
2.Engine board
3.SN cable
C The fuser drive system is operating properly and the cam disk is
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
Check the solenoid for proper operation,
making sure it picks during POR cycle.
Disconnect the solenoid and check the
resistance on the solenoid cable. It should
measure approximately 65 ohms. If incorrect,
replace the solenoid.
Check the voltages on the solenoid cable
connector.
Check the following voltages on the contact
cam solenoid cable connector:
Voltage Static Picked
1 (Red) +24 V dc +24 V dc +24 V dc
2 (Black) -SL2ON +24 V dc 0 V - +24 V dc
Note: All voltages are approximate.
continuity of the CRF cable to the cam
solenoid.
Assembly
Check the clutch spring, clutch boss, clutch
disk and gear C4 for signs of wear, broken
teeth or binds. Repair or replace the motor
mounting stay assembly if a problem is found.
Normaly the fuser is not turning - check the cleaner pad is not jammed in too tight. Then replace the fuser drive block 12G1348.
Jul 29, 2009 | Lexmark C510 Laser Printer
Error message 993, what is this?
that is a fuser drive error on printers. it is the part that fixes the ink to the paper.
i have a check for you but is not an easy fix.
if fuser drive is gone will cost approx £12 to replace.
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio GX3050N Printer
Gx3050n error code 993 what is this?
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio CL1000N Printer
Power loss
Try unplugging and then plugging the TV back in. If you can now turn it back on then you have a bad main board. If this does not make any difference then you have a bad power board. Hope this helps.
Nov 13, 2008 | LG 26LX1D 26 in. LCD HDTV
Print head assembly on my Lexmark Optra S 1855 needs to be replaced. My question is what causes the print head to malfunction in the first place?
I guess you're getting an error message which is normally one of the below (causes underneath)
Error Code 931
No first HYSNC Signal
Error Code 932
Lost HYSNC =
These errors usually indicate a
failure in the HYSNC signal to the
printhead. Check the continuity of
the cables connected to J3 and J8
on the engine board. If incorrect,
replace the defective cable. The
voltage at J8-4 measures
approximately +5 V dc. If incorrect,
replace the engine board. The
voltage at J3-7 measures
approximately +24 V dc. If incorrect,
replace the engine board. If correct,
replace the printhead assembly.
Error Code 934
Mirror Motor Lost Lock
Error Code 935
Mirror Motor unable to
reach operating speed =
These error codes indicate a
problem with the mirror motor circuit
in the printhead assembly or the
mirror motor cable to the engine
board cable or engine board
assembly. Check the continuity of
the mirror motor cable connected to
J3 on the engine board. If incorrect,
replace the cable. The voltage at
J3-7 measures approximately
+24 V dc. If incorrect, replace the
engine board. If correct, replace the
FRUs in the following order:
engine board
printhead assembly
Jun 19, 2008 | Lexmark Office Equipment & Supplies
Transmission
govener gear is worn and has broken teeth on drivers side of tranny pop cover off its a circle shape on the side pull out govener order new 4 about 46 bucks and put new assembly in does not matter position
Jun 06, 2008 | 1984 Chevrolet Corvette
Broken cable connection inside board
No need to buy a PC board. Have professional tech solder leads back and tighten connector
Apr 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
22 people viewed this question
k24674
jasbo
jasbo
