Question about Dell Studio XPS 16 Notebook
How do i unlock the keypad? it doesnt work at all but the mouse pad is fine..
  • 408 Answers
The key board may need to be replaced or has become disconnected from the board.
Posted on Jul 28, 2009
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
Emachines netbook unlock key pad
Key Pad or Touchpad? Is it that the mouse pointer is frozen and does not work? If so, look at the middle of the touchpad at the top of it and there might be a button there that lets you toggle the touchpad between locked and unlocked.
Sometimes there might be a set of keystrokes you will have to hit to lock or unlock the keypad. Most times you will have to Press and Hold the Alt, FN or Ctrl key then hit the key (most times one of the F1 thru F12 keys) that controls the keypad. The key that controls the keypad will have the icon of a finger inside or pointing at a square that represents the keypad. On one laptop recently that I worked on it was toggled by Pressing and Holding the ALT key then hit the F6 key. F6 had a finger pointing at a square area representing the touchpad.
Apr 07, 2012 | eMachines eMD620-5133 Notebook
95 ford explorer battery went dead due to lights being left on, now keypad doesnt work
try closing and locking all the doors then unlock the drivers door with the key
Feb 26, 2012 | 1995 Ford Explorer
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
Keypad stack up
Just want to verify which key pad you referring to? The alpha numeric keypad or the touch pad for the mouse pointer control?
Try this first. Power on laptop then hold down F2, check if you can access BIOS. If yes try F8 then boot to safe mode. Check if you can login to windows in safe mode. If yes then do a system restore from the date where every thing was working fine.
Else replace the keyboard and keyboard cable.
Jun 01, 2011 | Computers & Internet
How to unlock keypad?
Hi Alina,
I guess you are having a problem with the mouse pad, on the left side you will notice one orange light on the pad, simply tap twice the pad the light will goes off and the pad will start working again,
I hope it will solve your problem
Regards, Bilal
Jan 11, 2011 | HEWLETT-PACKARD ProBook 4520s
Acer Aspire 3304WLMi keypad and mousepad not working
if you take a hard look at your laptop you'll probably find a key that to disable keyboard that with fn will do it
what type of laptop and model
also check in control panel mouse then device settings see if you disabled in there
Feb 01, 2009 | Acer Aspire 3000 Notebook
Mouse pad locked
have you recently installed new os or been into the bios for whatever reason.
quite often when restart from bios mousepad doesnt work;usually comes back on after shut down and reboot(not restart)
if you think drivers gone download driver from hp.com
Jan 03, 2009 | Medion md40298 Notebook
Open Questions:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.OverflowException: Value was either too large or too small for an Int32. at System.Number.ParseInt32(String s, NumberStyles style, NumberFormatInfo info) at BmLauncher.SystemInfo.GetPropertyInt(ArrayList info, String propertyName, Int32 property_index) at BmLauncher.SystemInfo.GetPropertyIntBest(ArrayList info, String propertyName, Boolean select_highest) at BmLauncher.SystemInfo..ctor() at BmLauncher.Form1.Initialise() at BmLauncher.Form1.OnLoad(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6407 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll ---------------------------------------- BmLauncher Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Program%20Files%20(x86)/Eidos/Batman%20Arkham%20Asylum%20Demo/Binaries/BmLauncher.exe ---------------------------------------- System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6402 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6401 (Win8RTMGDR.050727-6400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Management Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll ---------------------------------------- Accessibility Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.6387 (Win8RTM.050727-6300) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Oct 20, 2013 | Dell Studio XPS 16 Notebook
Dell Studio XPS 16 Notebook Logo
551 people viewed this question
Alun Cox
