Question about Dishwashers
DeLime light and detergents not flowing into dishwasher
The DeLime light will not disappear even after I have a solution to cure this problem thru the dishwasher. Also it will not draw detergent or rinse agent. We have checked the lines and they are not plugged. We also are using the recommended detergent for this dishwasher.
  • Ssnow Nov 20, 2007
    This dishwasher is a Hobart LX18
Make sure the probs are clean inside of unit.Lime build up and calcium deposits may have occurred.
Posted on Nov 21, 2007
How do I delime a Hobart LXE series dishwasher?
run load empty with a cup off salt in place of detergent
Aug 29, 2014 | LXeC Commercial Undercounter Dishwasher...
How much delime agent should I use to clean the system in a Hobart LXI-H?
Depending on how often you delime the dishwasher use 2 cups.The delime light will come on after 1000 cycles set from factory default.If the delime icon is lit and beeps,turn the unit off.
Push and hold the delime/wash button and on button for 5 seconds and youll be in delime mode.
The unit will fill and heat up and display "add delime".Open the door add the delime and press the wash button.The dishwasher will run for 5 minutes then rinse and drain twice then shut off.When you turn it back on the delime icon will be gone.I'm a hobart tech and repair these dishwasher often,any questions let me know and please rate me,Thanks.
Nov 24, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
The hobart lxih is stuck in delime.
To reset or clear delime message, on control board there are 3 buttons. from power off, drawer open, manget on door switch, door closed, hold PROG on board and press the ON key on keyboard. pressing select moves to next poption, up arrow increases setting. step through select until you see delime, settings for LXi are de for disabled, and 1 through 65= x100 cycles. rg if set at 5, after 500 cycles the message apears. To keep the settings and clear the message a delime sequence needs to be run precisely as described.
With machine off, remove rack , close door, press and hold wash/delime key and press ON. Delime will be lit on display, release wash/delime key, and let machine fill. you should then see ADD and DELIME on the display, open the door and add the delime agent following supplier's instructions precisely. close the door, press wash, delime will flash. After delime is complete power is turned off. Inspect the machine and repeat if necessary.
Jun 18, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How do you delime the hobart LXi. Where can I find the manual online?
With the unit off----hold the wash/delime button in and hold the on button in for 5 seconds.the dishwasher will fill and the delime icon will be on,then it will prompt you to add delime,add the delime and hit the wash button.It will run for 5 minutes,fill up twice and drain twice then turns off.
Feb 26, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwasher says delime on screen, how do i do this?.
You need to buy a calcium lime remover/lime remover and if you can see a bad lime deposit then please buy a stronger delime.You need to put the delime in the unit and run it through a cycle.Repaet this procedure more than once to get optimum results & get rid of the scale. Also try and delime it once in a month or two so that this doesn't happen in future.
Please rate this solution.
Feb 13, 2009 | Jackson Dishwashers
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
Jan 29, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lxih
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Jul 16, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
