Question about Kenmore Kitchen Ranges
Kenmore model 790.9912, oven will not heat, clock
K
kenmore model 790.9912, oven will not heat, clock will not reset, countertop ok, controls set up ok, except for clock.
Sea Breeze
  • 4654 Answers
SOURCE: kenmore oven
This oven may fall under the touch pad complaint that many customer are having, click link to see if your's is one. http://www.lieffcabraser.com/profileovencomplaints.htm
Posted on Oct 23, 2007
Powerman
  • 68 Answers
SOURCE: Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Posted on Nov 22, 2007
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
reg501
  • 413 Answers
SOURCE: I have a kenmore elite
The range has entered sabbath mode. Refer to owners on procedure for turning sabbath mode off. Also try to hold down "timer off" button for 10 seconds.
Posted on Jun 09, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave stops after about 2 seconds, also have to reset the clock each time
TO mdambros
You have a bad magnetron. We see this over and over.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
You'll save a lot by taking it in yourself.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
TO guest (Panasonic oven)
The door switch you suspected is bad, and it must be replaced. They normally cannot be cleaned or burnished and be reliable.
See http://www.microwavedisplay.com/doorsw.txt
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
Posted on Jul 01, 2008
Why Kenmore microwave oven (model 80089700) start/enter button not working while all other buttons works fine?
Safety system locking out the start switch. Door not closed, mode and timer not set etc.
Apr 10, 2017 | Kenmore Microwave Ovens
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
How to set clock on kenmore 721.62222300 microwave
Press the STOP/CLEAR button followed by the CLOCK button. Enter the numerical value of the time (example: 11:30 = 1, 1, 3, 0), followed by START.
These instructions are on Page 9 of your owner's manual. If you do not have a manual, you can download or print a copy for FREE at managemylife.com. For your convenience, here is a direct link to your manual:
http://www.managemylife.com/mmh/owner_manuals/11630/KENMORE-Countertop-Microwave-L0310005?brand_name_search=721.62222300
If you have questions, please post back and let me know. I hope this helps you.
Jul 02, 2010 | Kenmore 63792 Microwave Oven
Kenmore pro built in oven no work
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
NOTE_ You unit dose is not equipped with a reset button, or switch. The only way to reset, in this situation, is to unplug, or shutdown the appropriate circuit breaker for 5 minutes. Once the 5 minutes have passed, simply re-introduce power to the unit, and try to run a normal baking cycle, If the issue occurs once more, follow the above procedures.
Nov 23, 2009 | Kenmore Ovens
Oven over heating-control does not work
ths oven looks like it has a digital clock (eoc ) it has a sensor in the oven in the back/ ( oven probe) replace the probe first . you may also need the clock . its very expensive .mm
Nov 22, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Oct 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore built in microwave displaying "D" and wont heat.
"d" may mean demo mode. The first thing to try is a "hard reset". Unplug it from the power outlet for 10 minutes, plug it back in, set the clock, then try again.
Jun 06, 2009 | Kenmore 62622 Microwave Oven
Kitchen Ranges Logo
88 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
