Question about Toshiba Satellite M35X-S149 Notebook
Toshiba L35 Laptop will not charge, the charge does not register
I have a Toshibal L35 Laptop and for a while I would have the cord plugged into the battery and I would receive a message that the battery was low even though it was plugged in at the time, then it seemed that if I positioned the laptop a certain way it would switch to AC power and be fine for a little bit then go back to battery power, now no matter what I do I can't get it to turn on because there is no power going to it. Is it the cord? the Jack in the back of the Laptop? or the Battery? I don't think its the battery because that was holding a charge when it would get power.. Help.. I know NOTHING about computers!
  • meridith71 Jul 21, 2009
    the ac adapter plugs into the battery so I can't do that.
Had the exact same problem. New AC adapter fixed it.
Posted on Aug 12, 2009
    Habit-Forming:
  • 62 Answers
Try first to battery without removing your laptop and use only AC power supply adapter
Posted on Jul 21, 2009
  • Olaso Nelson D Jul 22, 2009
    is that the charger you together and battery chargers, try it may cause to be
    made in the electronics or battery charger will have problems
Clear cmos toshiba laptop satellite L35-S2174
Remove coin battery for 2 minutes, Computer will default to original new computer status. Make sure the 2032 coin battery is good.
Dec 26, 2012 | Toshiba Satellite L35-S2174...
Toshiba laptop adapter not working.should i go for a new original or is compatible duplicate safe
I will not recommend you to repair it, it's a sealed box, not worth it. Just buy another one. Always a 3rd party adapter will be more cost effective. Toshiba PA3215U-1ACA
Dec 09, 2011 | Toshiba AC Adapter/Power Supply Cord...
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
I replaced my screen on a toshiba L35 laptop and turned it on screen is black now comp is running . help please?
try first your laptop without using your laptop screen. remove laptop screen and testing display output from your CRT or LCD monitor. if display comes out, try to check your inverter.
Feb 04, 2011 | Toshiba Satellite L35-S2366 Notebook
Fixing DC Jack for Toshiba Satellite L35 cost how
I believe the L35 uses what is considered a satellite power jack which means the actual jack is not soldered to the motherboard but uses a cable and plug, therefore is the easiest of the power jack repairs. The cable can be found on ebay for around 30 bucks or less. I usually charge 50 bucks for the labor plus the part, the laptop has to be disassembled to complete the repair. Below is a link for disassembly if you want to use it as a reference and perfrom the work yourself.....
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L35/taking-apart-laptop-1.htm
Jan 04, 2010 | Toshiba Satellite L35-S2366 Notebook
My wife has a toshiba satellite L35-S2151 laptop. When she went to turn it on, the orange battery light flashes 8 times and nothing else happens. Any clue as to what is going on?
Try turning on the device with the power connected if it turns on, keep the power plugged in for the entire day. See if you will have the same problem without the power supply. If it still occurs without the power supply, you may have a bad battery, you can verify if you can get swap battery from a similar laptop.
Oct 01, 2009 | Toshiba Satellite L35-S2366 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Sir, i have a toshiba laptop. it is a satellite l35-s2366. its support window vista but i have download window xp after formating my laptop. i have no driver cd of this computer . i have download most of...
Here is the Toshiba site for support and downloads for your L35-S2366 laptop. Just copy and paste this into your address bar.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1700048&rpn=PSL33U&modelFilter=L35-S2366&selCategory=3&selFamily=1073768663&selModel=1700048|PSL33U
Dec 10, 2008 | Computers & Internet
Sound driver
Hi, I want to install sound driver on my laptptop model: Toshiba satellite L30. Please advise me.
Aug 10, 2008 | Toshiba Satellite L20-S310TD Notebook
Toshiba Satellite M35X-S149 Notebook Logo
371 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
