This graphics driver is not included in Vista. In order to get it to work follow these steps:
1) Download "d3drm.dll" from http://www.dlldump.com/download-dll-files_new.php/dllfiles/D/d3drm.dll/5.1.2600.0/download.html
2) Copy it in to the "c:\windows\system32" folder
Run your program again and it should work.
http://www.fix-all-dll-errors.com/d3drm.dll/
u can go to this site...this will help in case of missing or download dll's or errors in dll's..!!
I also registered few dll's from this site...worked in my case :)
If you get this error do the following:
Update DirectX
Reboot your PC
Reinstall the software (probably a game)
These have been suggested as fixing problems BUT the sure fire way i found was to do this:
Go here:
http://www.dlldump.com/download-dll-.../download.html
Download the dll file and save to your desktop , its not gonna be there long
Move the file from your desktop to one of the following folders:
32 Bit Systems
If you are using 32 Bit Version of windows go to your system32 file located here:
C:\Windows\System32
and move the d3drm.dll to that location and try running the program
64 Bit Systems
If you are running a 64 Bit system then move the file here:
C:\Windows\SysWOW64
Dont Know
If you dont know what version of windows you have then do the step for 32 bit windows and try running the program with the file there. If the program doesnt work then remove the file from where you just put it and move it to the location specified in the 64 bit windows user part. It is very likely one of these steps WILL work for you , if they dont im stumped
A little point to remember is that if you put the file in the location specified for 64 bit users and the game worked then it is likely that you are running a 64 bit system. It will come in handy to remember this.
Thanks~
Type 'd3drm.dll ' in google and download it.
Download this www.download.com/d3drm.dll
Unistall the game and reinstall it. Should solve the isue.
need d3drm.dll file
i dont open a program, window vista said error because de program donĀ“t have d3drm.dll
i'm trying to use my flight simulator on my windows vista and it's not allowing me.
i cant use an architect designing program
i have the fms flight simutalor and have the same problem. it says d3drm.dll is not loaded .. what can i do
I can't hear any sound from my PC after installing Vista Ultimate Edition. In device manager i saw my sound devices have a green mark. Please give me solution.
problem d3drm.dll
D3DRM.dll problem
my is not roning find
my motocross madness 2 did not work under vista ultimate edition.can you plz help me with a solution.
sim does not work
is there anyway that u can get a flight sim for vista
cant operate my flight simulator
cant run fms simulator
I have vista and can't play FM simulator 'cause it's that file missing, but I have tried everything!!
Yes, I have the same problem. I have downloaded the d3drm.dll file and copied it to the system 32 file but the simulator still gives the same error message. I have tried uninstalling and reinstalling the program and that doesn't work either.
i had the game working and then the next time i tried to start it it said that the game stopped working and that i needed d3drm.dll
I can not run the game becoz,d3drm.dll has not been found
cant run flight sim
I can't run my flight simulator bec vista is not loaded w d3drm.dll. I tried to download it from dll dump.com but, I am the administrator on my computer, but it wont let me download it to the windows/system32 folder because it keeps saying I am not the administrator, (even though i am logged in). please help.
non riusciamo ad usare fms simulator e non carica d3drm.dll
same problem
failure message d3drm.dll is not loaded
When I try to run older disk programs I get the same message
I'm not getting sound out put
CAN NOT RUN MY ESKY FLIGHT SIM - GET D3DRM.DLL NOT LOADED MESSAGE
i'm using windows vista and i loaded my FMS simulator CD. i couldn't operate as D3DRM.dll not loaded yet message appears..
as advised i downloaded D3DRM.dll in to zip folder and while extracted into c:\windows\system32
access denied message appears
i copied the same and pasted into system 32
but when i start the FMS simulator
the message D3DRM.dll not loaded yet appears again..
what shall it be ?... due to
pl advise me on this
Solution Link . . . http://www.microsoft.com/Windows-Vista
